» Sponsors
» Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6,7,8,X,Z - Series and Mini Cooper
6,7,8,X,Z - Series and Mini Cooper General Chat related to models that do not fit into particular categories above. Please try to put your discussion in more appropriate sections. This section does cover the MINI Cooper and 8-Series vehicles: BMW 830i, BMW 840Ci, BMW 850i, BMW 850Ci, BMW 850CSi, M8, Alpina B12, BMW CS Concept and others.
Old 12-30-2004, 04:29 PM   #1 (permalink)
Photos: 0
daves7x20 is an unknown quantity at this point
does anyone know about a fuel trim malfunction? Its on my OBDll #0173? I thought if I changed the fuel filter this would help. let me kn ow
daves7x20 is offline   Reply With Quote
Old 01-07-2005, 08:00 AM   #2 (permalink)
///Matt's Avatar
Photos: 0
in regards to the fuel trim malfunction, codes 0173, 1174 & 1175 are all signs of this problem. It can be a number of things, most likely a vacuum leak, (usually caused by temperature changes causing the manifold gaskets to break) however it could also be a fuel pressure problem. Being a 740il, with the M62 V8, it is probably the vacuum leak. Watch for cylinder misfires which suggests that the problem is getting worse. Take it to a mechanic and have him check out the air intake system. If this is the case BMW-Dealer mechanics will charge nearly $500. ghead
GOOD LUCK!
Old 01-09-2005, 07:06 PM   #3 (permalink)
TECH's Avatar
Photos: 0
[snapback]261259[/snapback]
Fuel trim rich, or fuel trim lean? Most likely lean. Check the intake boot for cracks or holes. Check the vacuum line on the back of the intake manifold.
With the engine running, spray some brake cleaner all around the intake manifold and the "backing plate" on the rear (pcv valve). If the rpm goes up noticeably by sucking in the brake cleaner, that's the leak.
Old 01-14-2005, 04:07 PM   #4 (permalink)
Photos: 0
GOOD LUCK!
[snapback]266187[/snapback]
Matt, thanks a lot, now I have something to work with, the dealer just changed the oil seperator and removed the intake to do so. I think there may be a conncetion. Thanks again. Ill let you know what happens.
Old 01-14-2005, 04:10 PM   #5 (permalink)
Photos: 0
Originally posted by TECH+Jan 9 2005, 07:06 PM--><div class='quotetop'>QUOTE(TECH @ Jan 9 2005, 07:06 PM)</div><div class='quotemain'><!--QuoteBegin-daves7x20@Dec 30 2004, 04:29 PM
[snapback]267657[/snapback]
[/b][/quote]
Hey TECH, Thanks for the info. Ill try this over the week end and let you know.
vB code is On
Fuel Leak ajreich 3-Series (E36) 1 11-13-2005 08:00 AM
Fuel Trim Additve Banks 1 & 2 Low dedahed 5-Series (E12,E28, E34, E39, E60) 9 09-23-2005 04:40 PM
Fuel Trim Malfunction - 1998 740i gm3mtm 6,7,8,X,Z - Series and Mini Cooper 1 08-13-2004 12:53 PM
X5: 0-60 in 4.0 tcpgv 6,7,8,X,Z - Series and Mini Cooper 6 03-30-2004 02:51 AM
