Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6,7,8,X,Z - Series and Mini Cooper
6,7,8,X,Z - Series and Mini Cooper General Chat related to models that do not fit into particular categories above. Please try to put your discussion in more appropriate sections. This section does cover the MINI Cooper and 8-Series vehicles: BMW 830i, BMW 840Ci, BMW 850i, BMW 850Ci, BMW 850CSi, M8, Alpina B12, BMW CS Concept and others.
Old 04-23-2004, 11:44 PM   #1 (permalink)
Photos: 0
tknesek is an unknown quantity at this point
I have a 2001 740il with 89,000 miles on it, have been noticing tire wear on outside edge of r/front tire. Had a mechanic put it on 4 wheel alignment and I have 5 degree of positive camber, causing the excessive wear, he looked and manuals show no adjustment for this front end with the sport suspension group.
Anyone have this happen before and what can I do to fix it????
Tknesek(themortgageman)
tknesek is offline   Reply With Quote
Old 04-24-2004, 12:29 AM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
ya 5 degress pos camber is a prob. I would suspect a bent component like possibly the strut housing or something. If your mechanic doesnt specialize in BMW's then maybe take it to a BMW specialty shop or a body shop who can inspect the steering and suspension components for either major wear or something bent. Also MAKE SURE that whoever is doing the alignment is weighting the car down with sandbags. BMW alignments are done weighted. There is a spec for how much weight and what the ride height should be after the weight is in. If this is not done then you can be sure the alignment was set incorrectly and this directly effects the camber spec! good luck
DT
http://dtbmw.com/dt540
vB code is On
Front Drive Shaft Loose On 325xi bmw_in_maryland 3-Series (E46, E90) 4 01-13-2005 07:44 AM
E46 Wire Guides (complete) EcianIce Audio and Electronics 2 09-26-2004 08:40 PM
A Ghost in my front end... Name: Shimmy Spector mathetas 3-Series (E36) 3 08-27-2004 11:47 PM
Ghost Haunting Front End: Shimmy Spector mathetas 3-Series (E36) 1 08-26-2004 09:40 PM
Help wiring up amp install lude69 Audio and Electronics 13 08-15-2004 11:24 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
