Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6,7,8,X,Z - Series and Mini Cooper
6,7,8,X,Z - Series and Mini Cooper General Chat related to models that do not fit into particular categories above. Please try to put your discussion in more appropriate sections. This section does cover the MINI Cooper and 8-Series vehicles: BMW 830i, BMW 840Ci, BMW 850i, BMW 850Ci, BMW 850CSi, M8, Alpina B12, BMW CS Concept and others.
Old 04-02-2004, 12:13 AM   #1 (permalink)
Photos: 0
audiosolstice is an unknown quantity at this point
Send a message via ICQ to audiosolstice Send a message via AIM to audiosolstice
in the info centre its telling me to check brake linings...as in the rubber ones going to each caliper in the front?
thanks
audiosolstice is offline   Reply With Quote
Old 04-02-2004, 11:58 AM   #2 (permalink)
b_OASIS's Avatar
Photos: 0
b_OASIS is an unknown quantity at this point
Send a message via AIM to b_OASIS Send a message via MSN to b_OASIS
Although the brakes are equipped with a brake warning pad system, the system only mintors one wheel per axle. There can be slight variations in brake pad wear at each wheel, so brake pad thickness should be checked whenever the wheels are off or brake work is being done.
The brake caliper should be unbolted from the suspension strut to properly inspect the brake pads and the rotors.
Brake pad Lining Minimum Thickness
*Front and Rear disc brake pads . . . . 2.0 mm (0.08 in)
I took this from my 98 Z3 Roadster Service Manual, by Bently Publishing. I should apply. When I took my car in for its Inspection II, I was told that the thickness meets minimum requirements as it is when it comes to the US specs.
Hope this helps.
b_OASIS is offline   Reply With Quote
vB code is On
E39 Check Brake Linings Light =\ FaKe_M5 5-Series (E12,E28, E34, E39, E60) 2 01-29-2005 01:23 AM
Inspection I iantosca 3-Series (E36) 5 09-18-2004 12:18 AM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
