Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6,7,8,X,Z - Series and Mini Cooper
6,7,8,X,Z - Series and Mini Cooper General Chat related to models that do not fit into particular categories above. Please try to put your discussion in more appropriate sections. This section does cover the MINI Cooper and 8-Series vehicles: BMW 830i, BMW 840Ci, BMW 850i, BMW 850Ci, BMW 850CSi, M8, Alpina B12, BMW CS Concept and others.
Old 02-21-2008, 07:24 PM   #1 (permalink)
Photos: 0
revharde30 is on a distinguished road
can some one help me
my 735il 92 model will not charge i put a new alternator and batery and still wont charge please help
revharde30 is offline   Reply With Quote
Old 02-21-2008, 11:09 PM   #2 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 330is
Photos: 0
what do you mean it wont charge? as in the car wont start? it doesnt have enough power to start? or the battery just dead after it runs out of juice?
I shall NEVER doubt the pirate again...
Old 02-22-2008, 02:04 AM   #3 (permalink)
Teh whore
AlpineSixAndSeven's Avatar
Car: 1986 325es, 1987 635CSi, 1976 Benz
Photos: 0
the alternator is not charging the battery.... still looking into the regulator....
Originally Posted by drz View Post
I'll never be bound to no man by means of a piece of paper
Originally Posted by My Auto Trans Teacher View Post
Butt plugs saved my life
Old 02-22-2008, 06:11 AM   #4 (permalink)
Photos: 0
yeah i put a meter on back of the alternator no charge coming out
Old 02-22-2008, 06:41 AM   #5 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Photos: 0
You replaced the alternator, the alternator is still spinning with the belts, you tested the alternator terminals during vehicle operation, and no voltage? Sounds like you replaced a bad alternator with a bad alternator.
1995 E38 740iL. Highly modded. Faster than you.
Lindsay fan club member.
Old 02-22-2008, 03:51 PM   #6 (permalink)
Photos: 0
i got the alternator from autozone when i took the first one off and took it and got it tested they said it was good but i went ahead and bought it anyways are they somthing in the car that makes it charge like a relay
Old 02-22-2008, 05:05 PM   #7 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
perhaps a bad input to the alternator, maybe a bad D+ connection or a bad ground.
DT
http://dtbmw.com/dt540
Old 02-22-2008, 07:59 PM   #8 (permalink)
Photos: 0
how would i check to c if thats bad
Old 02-23-2008, 11:33 AM   #9 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
you need to use a multimeter at the back of the alternator with everything connected check voltages at the large post with red wire (B+) as well as the small post (D+) You should have over 12v at each terminal. Change the meter setting to ohms and check betwen the case of the alternator and 1 of the bolts on the shocktower. You should have less than 1 ohm. Report back with results.
DT
Old 02-23-2008, 05:20 PM   #10 (permalink)
Photos: 0
its got 11.21 but the belt is kinda loose would that be the problem and its got 1 ohm
Old 02-24-2008, 11:49 AM   #11 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
11.21 at BOTH the thicker wire (B+) and the thinner wire (D+) at the back of the alternator?
is this measurement taken with engine running or not running?
does the battery light in the dash illuminate?
DT
Old 02-24-2008, 04:24 PM   #12 (permalink)
Photos: 0
11.66 on big abd 10.65 onlittle as engines running tightened u[ the belt it didnt help and no the batery light is not on so any ideas yet
Old 02-24-2008, 09:21 PM   #13 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
sounds like you have everything you need for the alternator to work... Id try another alternator. Also charge the battery ..
Regards,
DT
Old 02-24-2008, 11:02 PM   #14 (permalink)
Photos: 0
but it is a brand new alternator
Old 02-24-2008, 11:40 PM   #15 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
your alternator needs three things in order to charge.
1) power at B+ which is the big positive wire coming from starter
2) power at the D+ wire also referred to as an exciter wire which is the smaller wire which goes through the instrument cluster and feeds the back of the alternator on the smaller eyelet
3) ground.
We checked all of those things so unless you made a mistake in your measurements then it sounds like a bad alternator. Of course I'm not standing in front of the car so all I can do is make suggestions. I dont know much about autozone alternators because I only use facotry parts for BMW but years ago I used to buy alternators from Kragen and had terrible luck.. one time i purchased 4 alternators before I got a good one.
DT
vB code is On
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
