Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6,7,8,X,Z - Series and Mini Cooper
6,7,8,X,Z - Series and Mini Cooper General Chat related to models that do not fit into particular categories above. Please try to put your discussion in more appropriate sections. This section does cover the MINI Cooper and 8-Series vehicles: BMW 830i, BMW 840Ci, BMW 850i, BMW 850Ci, BMW 850CSi, M8, Alpina B12, BMW CS Concept and others.
Old 09-11-2004, 06:24 AM   #1 (permalink)
the bmw maestro's Avatar
Photos: 0
the bmw maestro is an unknown quantity at this point
In the future i might wanna buy my dream car, one of te 8-series
Is this a good idea, do they break down often, is it expensive to keep. is the handeling ok?
my dream, a b12
<img src='http://img.photobucket.com/albums/v134/HJHJH/850isign.jpg' border='0' alt='user posted image' />
the bmw maestro is offline   Reply With Quote
Old 09-11-2004, 05:47 PM   #2 (permalink)
Photos: 0
gm3mtm is an unknown quantity at this point
When is a bmw inexpensive to maintain? Don't know the 8 series that well.
gm3mtm is offline   Reply With Quote
Old 09-11-2004, 05:54 PM   #3 (permalink)
BMWLotAttendant's Avatar
Photos: 0
BMWLotAttendant is an unknown quantity at this point
Send a message via AIM to BMWLotAttendant Send a message via MSN to BMWLotAttendant
The 8-series is nice. If you're going to get one, get one with the bigger engine. The V12 handles nicely! Sporty and stylish....but something leads me to believe that they are hard to find. Since they are discontinued...only in production 9 years.
One day, a record sighting is 2 BMW 8-series at our dealership.
anyway, my thoughts.
BMWLotAttendant is offline   Reply With Quote
Old 09-11-2004, 06:26 PM   #4 (permalink)
Photos: 0
Gulelin is an unknown quantity at this point
A 12 cylinder 8 series would be the shiznit, but I imagine they are very rare.
Titsilver metallic 2004 330 Xi 6speed manual
Gulelin is offline   Reply With Quote
Old 09-12-2004, 07:53 PM   #5 (permalink)
Photos: 0
I have a 1988 750 and have seen/driven a couple of 850s. These cars are rare and as they get some age on them will require the normal replacement of parts and that my friend is where the cost factor comes in. Parts are expensive (go Internet/Ebay), and labor as well is not cheap. The V12 is a tight fit and the German engineering though great tends to be one of over engineering of everything. Example, my 750 has a self leveling rear suspension that is hydraulic and not pneumatic, the brakes are not power assist but have a hydraulic servo and hydraulic booster, and the steering is hydraulic as well and guess what pumps all of the fluid, the power steering pump. Rear struts are right at $300.00 each new, and a power steering gear box will run you about $700.00. I am not here to scare you off, the cars are great, but, you need to understand what you ae getting into. I, put aside $1000.00 per year for maintenance, do not always need to use it, but need to have it available.
Bubba
Old 09-12-2004, 07:58 PM   #6 (permalink)
6th Gear Member
e36_m3_Turbo's Avatar
Photos: 0
also be aware of the nikasil problem with the 840's if u think bout gettin one of those.
No longer red.
Old 09-12-2004, 07:59 PM   #7 (permalink)
6th Gear Member
Photos: 0
here is a link bout it
http://www.lestac.co.uk/bmw/nikasil.htm
No longer red.
Old 09-12-2004, 08:01 PM   #8 (permalink)
6th Gear Member
Photos: 0
it was mostly the block from engine was coated with nickel. which suffer breaks the nickel down and makes the block wear really bad, makin the compression drop and loss of a cylinder
No longer red.
Old 09-12-2004, 10:23 PM   #9 (permalink)
Photos: 0
Nikasil did not affect the V12 (M70) only the V8 (M60) and that was in the 1994-1995 era. Koala motorsport has a good write up on this issue.
Old 09-12-2004, 11:42 PM   #10 (permalink)
6th Gear Member
Photos: 0
i didnt say anything bout the v12. i said if he was thinkin bout the 840, then he might want to think obut that
No longer red.
Old 11-20-2004, 12:34 AM   #11 (permalink)
Merlin4SC's Avatar
Photos: 0
Merlin4SC is an unknown quantity at this point
Stay away from the old M70 V-12 as it had issues that affected its efficiency that you will not want to deal with in a car that weighs over 4,400 lbs.
Mine has the M73 which is the 5.4 litre, and has the most trouble free advanced control systems and design.
Although compression increased to 10.0:1, the valve train actually has less drag and friction -- the M70 didnt even have roller lifters. Reliability was greatly enhanced by the new Seimens electronic engine control system using the single CANBUS system. The engine was significantly lightened with such things as sintered hollow camshafts. It also runs much cooler due to better airflow path design and exhaust and oil cooled piston skirts. It also has the ability to take advantage of all the advancements in 100,000 mile wear items like Bosch Platinum +4 plugs, Bosch Design III injectors, synthetic Esso tranny fluid, etc etc.
There is actually a differences training manual by BMW between M70 and M73. You will find no ECM chips available for the M73 as BMW figured out what improvements others made, nor will you for the newer steptronic.
Fuel economy also improved with the much crisper shifting stepronic 5 speed 5HP-30 model. Only 363 of these caem to the US though.
If you want an 8 series, you cannot do better than the post Oct 95 850Ci.
It was discountinued for the US at end of 1997, and world wide 2 years later.
if you ever get the heads off, I highly recommend a port and polish too. You will get massively huge amount of tourqe and better milage. I get 22.5 mpg, and still make it to 60 mph from zero in 5.8 sec, but the real kicker is the 0-100 times due to the tall rear end 2.8:1. If you want an absolute rocket from 0-140 spend $800 and get a 3.15 rear diff [must be 25% LSD though].
Also if you are at all adept at working on it yourself, you MUST get the ETK and manuals on CD-ROM. This is the Falcon100 of business cars.
Merlin4SC is offline   Reply With Quote
vB code is On
Calling all BMW series 1 drivers in Berkshire Holly Looking For 0 10-31-2005 06:27 AM
BMW 8 series zlac109 6,7,8,X,Z - Series and Mini Cooper 2 10-25-2005 11:58 AM
BMW Ultraslim Driving Watch- M3 M5 5 7 Series johnny5x Non-Automotive Related 0 09-14-2005 04:36 PM
BMW Ultraslim Driving Watch- M3 M5 5 7 Series johnny5x Audio/Miscellaneous Auto Parts 0 09-14-2005 04:35 PM
BMW Ultraslim Driving Watch- M3 M5 5 7 Series johnny5x Aftermarket Parts 0 09-14-2005 04:33 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
