6,7,8,X,Z - Series and Mini CooperGeneral Chat related to models that do not fit into particular categories above. Please try to put your discussion in more appropriate sections. This section does cover the MINI Cooper and 8-Series vehicles: BMW 830i, BMW 840Ci, BMW 850i, BMW 850Ci, BMW 850CSi, M8, Alpina B12, BMW CS Concept and others.
Originally posted by Tom Taylor@Jun 19 2005, 04:08 PM I`ve had this car for two mo`s,Its needed a drive shaft and now reverse has gone out.They tell me that will be 3500.00 @ 118k mi.whats next?
[snapback]355021[/snapback]
As it seems to be moving forward must be the engine.
Well she is 11 years of age, and driveshafts on these cars seem to last (IMO)about 150,000 miles, mine went at 135,000. Transmissions with proper care, drain and filter change on a regular basis should go, hopefully 200,000 miles. You are probably aproacihng suspension component replacement (if original) as well as hoses, belts and fuel lines, and maybe a fan clutch as well. This is not menat to scare you but to let you know what MAY be next.
Take in count, that prior owners may not have taken good care of it.
Taking good care makes good things last a awful good longer
GOOD GOOD GOOD
__________________ <span style='color:red'><span style='font-size:10pt;line-height:100%'><span style='font-family:Comic Sans MS'>Track Day Cars:</span></span></span>
<span style='color:blue'><span style='font-size:9pt;line-height:100%'><span style='font-family:Comic Sans MS'>BMW E30 320i M20B20 MY87</span></span> <span style='font-family:Comic Sans MS'><span style='font-size:8pt;line-height:100%'>- Bad body, everything else is good ! (organ donor)</span></span>
<span style='font-size:9pt;line-height:100%'><span style='font-family:Comic Sans MS'>BMW E30 325e M20B27 MY89</span></span> <span style='font-family:Comic Sans MS'><span style='font-size:8pt;line-height:100%'>- Bad body, bad wiring, everything else is good ! (organ donor)</span></span>
<span style='font-size:9pt;line-height:100%'><span style='font-family:Comic Sans MS'>BMW E30 3xx? MxxBxx MY89</span></span> <span style='font-family:Comic Sans MS'><span style='font-size:8pt;line-height:100%'>- Good Body, no wiring, no engine ! </span></span></span>
<span style='color:red'><span style='font-size:10pt;line-height:100%'><span style='font-family:Comic Sans MS'>Daily Driver:</span></span></span>
<span style='color:blue'><span style='font-size:9pt;line-height:100%'><span style='font-family:Comic Sans MS'>BMW E39 523i M52B25 MY99</span></span> <span style='font-family:Comic Sans MS'><span style='font-size:8pt;line-height:100%'>- Being Purchased (Mint Condition)</span></span></span>
The problem is a valve in the transmission. it happens with that type of transmission typiclly. it shoul be less than 1000 bucks. There is a replacement kit that you can get. Keep Googleling BMW 740 il and Transmission Program and you will get the web sites and forumns that helped me to resolve that issue last year. Good luck
