Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 6,7,8,X,Z - Series and Mini Cooper
6,7,8,X,Z - Series and Mini Cooper General Chat related to models that do not fit into particular categories above. Please try to put your discussion in more appropriate sections. This section does cover the MINI Cooper and 8-Series vehicles: BMW 830i, BMW 840Ci, BMW 850i, BMW 850Ci, BMW 850CSi, M8, Alpina B12, BMW CS Concept and others.
Old 06-13-2008, 09:35 PM   #1 (permalink)
Photos: 0
Steve89735IL is on a distinguished road
'89 735IL A/C questions
Good evening all,
Looking for help as I am my neighbors mechanic on his '89 735 IL!! We are having issues where the a/c seems to be working fine, but the heater is also on at the same time. This car has dual climate control. In the off setting, eveything is off, during the winter in the heat setting everything appeared to work fine. Now that we have charged the a/c and attempting to make it cool (it is 98 here in Texas), the a/c is running, cooling, but we then are getting hot air overriding the a/c system. When engine is cold--first start up--a/c works fine, but as engine heats up, the heater evidently is also. We think it is only the passenger side, but now not sure. Does this sound like a servo problem, a circuit board issue, or what? I am scratching my head as I have lots of experience with cars, but not BMW. Any suggestions? Thanks, Steve
Steve89735IL is offline   Reply With Quote
Old 06-13-2008, 09:43 PM   #2 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
Moving to proper section, you'll probably get more exposure there. I am leaving a redirect in here for one week.
-There's no place like 127.0.0.1
-"Wheel Sucks"
Old 06-13-2008, 10:35 PM   #3 (permalink)
To the left ...
Torque's Avatar
Car: '90 535im
Photos: 0
Send a message via AIM to Torque Send a message via MSN to Torque
Couple things to look at:
-First make sure you don't have the dial in the center of the dash set to the "red" heat settings; it controls a little stepper motor that allows you to fine tune the air temp. I really doubt this is the issue, but ... you never know; often it's the simple things being overlooked.
Just a FYI, there is a dozen or more of those little stepper motors throughout the car that fine tune the air temp and all sorts of crap; sadly it's all getting very old so it's prone to failure. Just hope it isn't one of those ... first I honestly (even after about 5 years of owning these cars) have no idea where they are, and second it means ripping out the whole interior to test and replace them ... and they're expensive too ...
That said, I'd start by checking the actual A/C controls; if you have the fancy controls ... you know, the automatic climate control with the horizontal dials, then it's possible that's bad. The sheer amount of "stuff" that does is amazing ... bad part is it's hard to find them to swap and see if that fixes it. If it's the regular one with the 2 temp knobs and 1 fan speed knob, then I'd swap a good unit in and see if that solves anything.
Old 06-13-2008, 10:39 PM   #4 (permalink)
To the left ...
Torque's Avatar
Car: '90 535im
Photos: 0
btw, air conditioned air will only be blowing out the dash vents; so make sure you have it switched to just that. The car is not designed to blow cold air through other vents (and guess what allows it to do this: blow heat everywhere, yet only blow cold air through the dash? yup you guess right, those stepper motors.) It's a hugely complicated system in the e32/e34 ... a real nightmare sadly.
Old 06-14-2008, 10:38 PM   #5 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 99 C43 AMG, 89 300SEL
Photos: 0
Send a message via Yahoo to darkhorse737 Send a message via Skype™ to darkhorse737
Lightbulb
given what you said, and i assume that you stated you case accurately, i would start looking at the AUTOMATIC HEATING & A/C CONTROL UNIT.
it's located between the front footwells ahead of the IKHA plenum
the "blow heat" is the default setting when the control unit malfunctions ;-)
...and yes, may i humbly say: "this is the wrong forum to postthis query"
Old 09-18-2008, 12:54 PM   #6 (permalink)
Photos: 0
Ac
Take a look at Johan and Sean's site:
http://www.bmwe32.masscom.net for a good description of the stepper motors and repairs.
Old 09-18-2008, 12:55 PM   #7 (permalink)
Photos: 0
Ac
Johan & Sean's E32 Page
Sorry.
vB code is On
1989 735IL New To BMW Need Help!!! chad107utah 7-Series 3 06-29-2008 12:00 AM
735il not charging need help revharde30 7-Series 7 03-19-2008 06:16 PM
94 530i Vs E32 735iL Scotty Dangles Driving Tales 2 09-07-2005 01:34 PM
1989 735il Info Please! Kickcity 6,7,8,X,Z - Series and Mini Cooper 4 11-05-2004 01:56 PM
88 735il purchase? Vegas1 6,7,8,X,Z - Series and Mini Cooper 0 01-06-2004 12:57 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
