6,7,8,X,Z - Series and Mini CooperGeneral Chat related to models that do not fit into particular categories above. Please try to put your discussion in more appropriate sections. This section does cover the MINI Cooper and 8-Series vehicles: BMW 830i, BMW 840Ci, BMW 850i, BMW 850Ci, BMW 850CSi, M8, Alpina B12, BMW CS Concept and others.
I was wondering if anyone knew where to get a fuse box diagram identifying the fuses ans relays on a 95 840ci. I checked the dealers and they cant get one. Thanks
You won't find a diagram anywhere. It's strange, the label is attached to the box. Anyway, no worries. I'll drive the car tomorrow and a take a couple of pics!
Steve1, I hope this works. I took a picture of the cover. I didn't see a diagram for the rear circuit breaker/fuses.
The PDF file was too large. so here is a pic instead.
Upper right corner box, there are 4 fuses (you can barely read it on the pic). Anyway, the numbers are
48
51
60
63
thank you for that, have you ever had a problem with your headlights, mine seem to only go up or down during the day when the car has not been driven too much.
I'm glad to help.
No problems so far. That's strange... Check both of your batteries (and fuses, ha ha)... The headlight motors are supposed to last very long! In any case, read your owners manual in case you have to raise your headlights manually. Also, where are you located? Is that the only problem for the headlights? If they're too loose inside the bucket or ifthe adjustment screw is broken, BMW might be able to replace them for free. I have a letter you can take to the dealer just in case. Send me your email privately if you want. The implied warranty is good for 15 yrs I believe.
if you just bought this car, check out this sites... www.e31.net (this is a great site for model history). Click on links for additional sites.
