Your 530i Leak Rain in a Downpour? - BMW Forum - BimmerWerkz.com
post #1 of 15 (permalink) Old 09-23-2009, 08:10 AM Thread Starter
longrob is on a distinguished road
On my 2002 530i I first noticed some leaking when I was pressure washing the car and water leaked in the rear door. Of course I don't do this anymore and I've never been a fan of pressure washing anyway, just use it to initially rinse the car.
But now if it rains a lot, my back passgr floorboard is soaking wet. I don't see where it is leaking. Any experience with a fix? common problem?
-Rob
longrob is offline
post #2 of 15 (permalink) Old 09-23-2009, 08:37 AM
Quoted: 1 Post(s)
Do you have a sunroof? If so, the drains may be clogged.
witeshark is offline
post #3 of 15 (permalink) Old 09-23-2009, 08:47 AM Thread Starter
Yes, I have a sunroof but have never seen the drains. where they be? but might I see roof leaks from this? thx for any help.
bet it rains some in Miami, huh?
longrob is offline
post #4 of 15 (permalink) Old 09-23-2009, 08:56 AM
Quoted: 1 Post(s)
There are drains at each corner that run down the A and C pillars; pouring a measuring cup at each corner (roof open of course) will let you see which drains work as the water comes out under the car. And yeah, we get very heavy downpours here, sometimes it almost looks like fog!
post #5 of 15 (permalink) Old 09-23-2009, 09:03 AM Thread Starter
Thanks for that tip. How would I clean the drain, is it big enuogh to insert something ?
longrob is offline
post #6 of 15 (permalink) Old 09-23-2009, 09:20 AM
Quoted: 1 Post(s)
I think they are big enough, but I've never tried it. Instead, I've just run water through each one at every washing of the car.
post #7 of 15 (permalink) Old 09-23-2009, 09:44 AM Thread Starter
I'll try that as a test of the sunroof drains.
Any chance the rear door seals are the problem?
-Rob
longrob is offline
post #8 of 15 (permalink) Old 09-23-2009, 09:57 AM
Quoted: 1 Post(s)
-Rob
There's no reason to assume not.
post #9 of 15 (permalink) Old 09-28-2009, 06:16 PM
harryooo is on a distinguished road
Water leak on rear floorboard,
-Rob
Hello I have had a water leak problem for over a month now. I finally figured it out. 2003 530I
I recently changed my trim window to shadow black, the leak seem to have started then. Anyway I took off the inside door panel , and discovered the inner foam plastic had separated from the door at the bottom. So I re sealed it. It dryed in 1 hour and I now have no more leaks. I guess the air pressure from closing the rearr door over the years caused it fail. Harry Jones
harryooo is offline
post #10 of 15 (permalink) Old 09-28-2009, 10:19 PM Thread Starter
Thanks, Harry
I have never taken off the door panel to look inside. What did you seal it with?
-Rob
longrob is offline
post #11 of 15 (permalink) Old 09-30-2009, 02:27 PM
Water leak 530I
I used windshield sealer from auto zone. It worked very well.
harryooo is offline
post #12 of 15 (permalink) Old 10-01-2009, 11:50 PM Thread Starter
Harry,
How do the door panels come off? I don't want to break anything. Are they just clips that I would pry off?
Thanks for any info.
-Rob
longrob is offline
post #13 of 15 (permalink) Old 10-02-2009, 09:27 AM
530i leak
First I had to take the hex head screw out of inside the door handle.
Then I took a flathead screwdriver and ran it along the bottom . I pryed popped the door panel loose. It snaps off easily . It would be hard to break it.
You do not have the take the whole panel off..Just pull it out ...
harryooo is offline
post #14 of 15 (permalink) Old 10-02-2009, 10:19 AM
Help from over the pond
marti5's Avatar
If your sunroof drains need clearing, I use the twine from a garden strimmer.
marti5 is offline
post #15 of 15 (permalink) Old 10-02-2009, 12:53 PM Thread Starter
Thanks Marti and Harry, all good tips!
I poured water at the back corners of the sun roof. It drained out the back ok. I'm sure I have an inner door panel problem that needs resealing. Seems quite sommon I hear.
-Rob
longrob is offline
2001 BMW 530i gas leak fojekl 5-Series (E12,E28, E34, E39, E60) 3 04-18-2008 06:24 PM
Rain Rain Go Away Neil Paz 3-Series (E21, E30) 11 02-27-2007 07:52 PM
Rain Water Leak in floor board ddlrk 5-Series (E12,E28, E34, E39, E60) 6 09-21-2004 10:19 PM
