Wierd electrical stuff... No brake lights, no instrument cluster - BMW Forum - BimmerWerkz.com
post #1 of 5 (permalink) Old 01-22-2008, 03:17 AM Thread Starter
d3ity will become famous soon enough d3ity will become famous soon enough
Having a very similar problem to sp0rky's (I think)
Is it just really waaay too cold out?
My dash used to come up with "Brake Light Circuit" every couple of days. Only my left brake light will go out. Soon this became a constant problem and my left brake/tail light will go out. My turn signals operate perfectly.
I assumed this was the cheap bulbs that came with my after market tail lights.
Replaced all the bulbs today. It's 18*F outside. took taillight out and replaced all bulbs. Right side brake light no longer functions. Left side is completely out except for turn signals.
More disturbing. As I was driving my car out of the parking lot my gauge cluster worked for a few seconds, then died. No gauges function. I can get my spedometer and tachometer working by pressing the reset button for the trip odometer. This causes the odometer readings to light up for a few minutes before they die again. Temperature guage, Fuel Guage, Mileage, spedometer and tachometer fail to work. Turn signals and ASC display properly when I press buttons.
Notice #1 Fuse was blown. Cruise control, taillights... etc. Replaced fuse. Guage cluster worked for 30 seconds before fuse blew again.
Got home. Started googling. Replaced LKM with another one I had lying around. Replaced #1 fuse again.
Fuse did not blow, but guage cluster still doesn't work. Taillights still running into trouble.
I thought about doing this: BMW E34 Website
in order to fix the problem... I'd like to avoid it though. Does anyone have any idea what could be causing this? It seems like so many of the car's systems are tied to that fuse, what should I check first?
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
d3ity is offline
post #2 of 5 (permalink) Old 01-22-2008, 01:23 PM Thread Starter
UPDATE: Checked codes with code reader.
Code 2A : Vehicle speed signal not present.
Anyone make anything of that?
d3ity is offline
post #3 of 5 (permalink) Old 01-24-2008, 11:19 PM
CosmosBlack's Avatar
CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute
Faulty ignition switch?
Or maybe a broken fusible link?
Both are common problems.
2012 Porsche 911 GTS
2008 Ford F150 Foose Edition
2010 VW Touareg
Gone...2002 Porsche 911 C4S
Gone...2000 BMW 540i
Gone...1995 BMW 540i
CosmosBlack is offline
post #4 of 5 (permalink) Old 01-24-2008, 11:24 PM
Sodium Chloride
saltshaker185's Avatar
saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold
check the wiring harness on your trunk... pull back the black sleeve and see if any wires are broken... if so, mend
saltshaker185 is offline
post #5 of 5 (permalink) Old 01-25-2008, 11:51 AM Thread Starter
Saltshaker you hit it on the head.
Brake light wire was pinched... touched bare metal and grounded. little solder and heatshrink later everything works perfectly.
d3ity is offline
electrical issue, please help Dr Tran 3-Series (E21, E30) 3 03-22-2007 02:34 AM
Idiot Light For Brake Lights Comes On Often... mikeyboy_esq M-Series (M1, M3, M5, M6) 3 08-19-2005 03:32 AM
Battery In Instrument Cluster? 325eXTATIC 3-Series (E21, E30) 4 04-10-2005 04:28 AM
Instrument Cluster From An E36 funtoos 5-Series (E12,E28, E34, E39, E60) 1 12-11-2004 11:24 PM
electrical of licence plate, rear side lights javieruz 3-Series (E21, E30) 1 03-14-2004 09:08 PM
