white smoke - BMW Forum - BimmerWerkz.com
Old 11-07-2012, 06:30 PM   #1 (permalink)
Car: 1995 BMW 530I
cj1995 is on a distinguished road
white smoke
Just bought a 95' 530i. Was missing slightly when I bought it. Changed the plugs and it ran fine for a few minutes, then started blowig thick white smoke, and missing at ide, and clearing up wen revved up. I'm thinking blown head gasket. It also had a coolant leak when I bought it. I figure the previous owner overheated it, thus blowing the head gasket. I'm new to the bimmers, so is there anything else that would cause this issue?
Thanks in advance!
cj1995 is offline   Reply With Quote
Old 11-07-2012, 07:21 PM   #2 (permalink)
sktn77a is on a distinguished road
Could be. First of all, check the CCV that can cause similar problems (and is a cheaper fix than a new head). The E34 V8s had a lot of problems with the block, too.
sktn77a is offline   Reply With Quote
Old 11-08-2012, 08:27 AM   #3 (permalink)
Car: 1995 BMW 530I
ccv
what is a CCV? And how and where do I / can I check it?
Thanks
Old 11-08-2012, 10:48 AM   #4 (permalink)
Crank Case Ventillation valve (BMW's unnecessarily complicated and expensive EGR valve)!
Old 11-09-2012, 07:03 PM   #5 (permalink)
ZenitramNaes is on a distinguished road
Did you check under the valve cover for evidence of radiator fluid? If yes it's clear your HG is blown.
Sent from my iPhone using Autoguide.com App
ZenitramNaes is offline   Reply With Quote
Old 11-10-2012, 06:49 AM   #6 (permalink)
Car: 1995 BMW 530I
I didn't pull the valve covers. There is nothing on the oil cap or in the anti-freeze. It's just missing at idle and blowing thick white smoke. It smooths out when I rev it up, but after 20 mins, it is still blowing thick white smoke. I'm thinking the HG is blown between cylinder and water jacket. Parts alone are $400, not to mention the labor.And that don't include replacing a head if needed. I can get a motor for $600, and it would cost me another $50 for oil, filter, and anti-freeze, plus $300 to install it. Haven't got a price on labor for doing HG's yet. Thought I got a deal, guess not.
Old 11-10-2012, 08:25 AM   #7 (permalink)
There is a really detailed thread on how to replace a head gasket on an m30 over at bimmer forums. I would post the link but I'm on my phone.
Old 11-10-2012, 08:39 AM   #8 (permalink)
Car: 1995 BMW 530I
I beleive mine is the M60 V8 motor.
Old 11-10-2012, 09:24 AM   #9 (permalink)
Oh sorry about that. Damn iPhone app doesn't tell me what section I'm in.
Old 12-04-2012, 01:16 AM   #10 (permalink)
rajendersingh90 is on a distinguished road
could be the problem related to carborators.. it could be out fo service from its functions
rajendersingh90 is offline   Reply With Quote
Old 12-04-2012, 05:23 AM   #11 (permalink)
Car: 1995 BMW 530I
It's TBI. No carbs.
Old 12-09-2012, 10:00 AM   #12 (permalink)
Car: 1989 BMW 535i
rivroshaun951 is on a distinguished road
Don't know if it's to late but another problem that is overlooked a lot is incomplete combustion can cause white smoke. Normally really thick white smoke Is incomplete combustion and a foggy kind of white is coolant being burned. First start with the coolant level. Is it low? If yes head towards blown head gasket. Try performing a pressure test on your coolant system this test can help you narrow down to a blown gasket. Incomplete combustion can be caused from multiple issues, for example incorrect timing, Bad Fuel, Compression problems, ignition problems, etc. etc.
rivroshaun951 is offline   Reply With Quote
05 525i NEED HELP White Smoke alee1 5-Series (E12,E28, E34, E39, E60) 5 12-05-2009 03:53 PM
White smoke rplant 3-Series (E21, E30) 13 10-08-2009 08:30 AM
White Smoke mo_joe88 3-Series (E36) 10 10-11-2007 09:17 PM
E30 eta White Smoke JoeMadoo 3-Series (E21, E30) 7 12-30-2005 10:58 PM
White Smoke zeidakiss 3-Series (E36) 20 08-09-2005 05:42 PM
