Where to put jack stands? - BMW Forum - BimmerWerkz.com
Old 04-30-2006, 09:48 AM   #1 (permalink)
tracetrimble is on a distinguished road
Hey all, first post. Looking forward to participating in these forums, and I need some quick help.
We bought a 2002 540i a couple mos ago with 50K on it. Doing my first real work on it (brakes), and need to know if this location is OK for jackstands. It's the ONLY place that I find up front besides the jack points that is symmetrical with the other side and looks almost beefy enough:
tracetrimble is offline   Reply With Quote
Old 04-30-2006, 11:44 AM   #2 (permalink)
Eric S.'s Avatar
Eric S. is on a distinguished road
Exclamation Don't do it!!
I don't recommend you try to jack-stand that point. Please check out:
http://www.bmwtips.com/
Under Tips & Tricks, check out tip #26 under the General category, entitled, "Jacking Points".
I've used this methodology many times on my '99 540 with no ill effects so far. In fact, I just finished 2 weeks on jack stands changing out my struts, springs, and sundry suspension control arms. As far as the wooden ramps referenced in the article are comcerned, I made mine out of a single 8' long 5/4" pressure treated deck board. Three layers each. It works great and gives me 'just' enough room to get my floor jack underneath.
I hope this helps!
<span style='colorurple'>Eric S.</span>
2006 Honda Odyssey EXL-RES
Eric S. is offline   Reply With Quote
Old 04-30-2006, 01:52 PM   #3 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
why does it seem like bmw always makes jacking points hard? other cars i work on is obvious and easy to jack them up... bmws are different...
Old 04-30-2006, 05:09 PM   #4 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
BMW Jacking points
Old 04-30-2006, 05:22 PM   #5 (permalink)
Sodium Chloride
Car: 95 M3
Originally Posted by Torque
BMW Jacking points
beautiful! haha nice job torque! does anyone know if these are the same points for an e36?
Old 05-02-2006, 01:55 PM   #6 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Excellent!
Can't get any clearer thant that! I'm saving the pic for future info!
Thank you,
LOS
Old 05-02-2006, 02:00 PM   #7 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Originally Posted by LOS
Excellent!
Thank you,
LOS
I had to flip a car for you guys. See how nice I am. :lol:
Old 05-03-2006, 10:53 AM   #8 (permalink)
Well, I got impatient on Sunday and went ahead and dropped it on those points. I did let it down very slowly and watched for any flexing. No ill effects, but I'll use the other method in the future. I agree on the jacking points in general - they make these cars so easy to do work on, if you can just figure out how to jack it up! Thanks guys.
Old 05-03-2006, 11:16 AM   #9 (permalink)
RexKing86's Avatar
Car: 2006 Mitsubishi Lancer Evolution MR
RexKing86 is an unknown quantity at this point
Send a message via AIM to RexKing86
I know, I always fear jacking up mine...
RexKing86 is offline   Reply With Quote
Old 05-03-2006, 12:44 PM   #10 (permalink)
Eric S.'s Avatar
I hope you guys noticed that the car shown rolled over in Torque's post is NOT an E39, and I think the original question came from an E39 driver. A close look reveals some obvious differences in the underbelly structure (note the lack of suspension subframe for instance), so I would advise caution. Once again, I recommend consulting the link I provided above, which IS specific to the E39.
Old 05-03-2006, 01:46 PM   #11 (permalink)
I don't remember seeing that center jack pad in the bmwtips link. Where is it? On the K member? I'm the OP with an E39.... guess it's time to enter a sig. Thanks again.
Old 05-03-2006, 03:28 PM   #12 (permalink)
Eric S.'s Avatar
Yes, the reinforced part at the center of the subframe is what I always use. It's just aft of the plastic belly pan/cover - in fact, be careful not to crush the little metal bracket at the rear of the pan. The pad shown in bmwtips was apparently just a 6-cylinder thing.
Where Do Jack Stands Go Exactly?? Brian325i 3-Series (E36) 5 10-11-2004 12:55 AM
Supporting car on jack stands scottm 3-Series (E46, E90) 1 05-12-2004 10:59 AM
Jack Stands hartzj 5-Series (E12,E28, E34, E39, E60) 1 10-26-2003 05:46 AM
