where can I find instructions for radiator install - BMW Forum - BimmerWerkz.com
Old 01-25-2004, 10:03 PM   #1 (permalink)
sj_525nut is an unknown quantity at this point
I have a '93 525i, can anyone point me to instructions on installing a radiator and is it a difficult job ?
sj_525nut is offline   Reply With Quote
Old 01-26-2004, 01:19 AM   #2 (permalink)
TECH's Avatar
It's simple. I don't have any links or anything though. The clips that hold the upper radiator require you to stick a small flatblade into the top of the clip to release it. Remove the fan if need be with a 1 1/4 wrench, tap it with a hammer clockwise to loosen fan from water pump. Remove fan shroud. Remove coolant hoses, and the auto trans cooler lines if you have those. That's about it.
Make sure you crack the bleeder screw when you fill the system to properly fill it.
Old 01-26-2004, 09:08 AM   #3 (permalink)
Thanks alot, I just completed a radiator replacement on my rx7 and it went pretty good, this sounds a lot easier.
I plan on getting it from speedycarparts.com, hows their rep ? I saw in one of the treads that the Nissens was better than the Behr, do you have any opinion between the two ?
Thanks for your help, I'm going to get right to work as soon as the 8" of snow clears.
97 540ia, Coolant leak, but cant find the source! ///Matt 5-Series (E12,E28, E34, E39, E60) 7 11-08-2005 11:25 AM
Help! Trying to find engine casting #... swenpro 5-Series (E12,E28, E34, E39, E60) 7 10-08-2005 11:19 PM
Cant Find This Article... kijana M-Series (M1, M3, M5, M6) 0 03-03-2005 02:18 AM
Mechanic asked me to find something for him... jrhaile 3-Series (E36) 4 09-04-2004 11:57 PM
