There is a red LED/bulb below the rear vent. (center of front two seats). You can see this only from the rear seat. What is this bulb for? I don't even know if this car ever had a remote. (previous owner gave me a key only). 1995, 525i, E34, Auto. Thanks for the help.
I tried to take the rear seat out. But I could not take it out. Seat is attached by a couple of tabs in the front. What do I need to do to release the tabs? I tried pushig the flat head screwdriver in the hole, didn't work. I tried twisting and turning, didn't work. My owners manual doesn't say how to take it out. Manual talked about touring model.
OK, I have a similar question (hope you don't mind).
I have a LED on the right side of the steering wheel (if you drew a line vertically through the steering wheel it would be exactly on the opposite side of the light switch). I've seen some e34 with it and some without. Is it the same alarm led as the one beautyland has on the rear vent ? Where is the unit in this case if there is one.
B-land...
try pulling the bottom seat (cushion) up... open the side door and pull from the bottom corner of the seat up, then do the other side until the whole bottom seat is loose. You will hear a snap sound. To put the seat back, push the corners down on each side, you'll hear the snap sound again.
Torque,
I was not aware about this LED light on the dashboard... sounds like an aftermarket alarm... Check the rear seat and see if the unit is there...
Also, there is some good info on this site, CIRCLEBMW.COM
Go to the service icon and click on tech information for additional info regarding the alarm unit.
OK...
The LED by the radio, it's some type of anti-theft devised for the radio. If it's stolen it won't work. It'll need to be program by the dealer and hopefully they'll know it was stolen.
The LED by the vents, it's a temp sensor, the alarm LED is on the bottom of the rear view mirror (on 97+ models)
Torque,
check underneath the dash board for the alarm (if it's an aftermarket unit)
