Weird starting issue... - BMW Forum - BimmerWerkz.com
Old 06-13-2007, 12:41 AM   #1 (permalink)
ozarkmark's Avatar
ozarkmark is an unknown quantity at this point
Question Weird starting issue...
Occasionally, my 528i will turn over for a few seconds but not crank. If I depress the gas pedal about half way it will start up. Sometimes I need to hold the gas pedal just enough for the idle to set in and everything is fine. This happens about once or twice a month but I always get her running and no problems for several days.
Any ideas on what I need to look at to make sure I don't get stranded?
I did a thorough search and didn't see any post similar to this.
1998 528i - sold 222,000 miles
1998 540i - sold 159,000 miles
2007 328i Coupe - 30,000 current
ozarkmark is offline   Reply With Quote
Old 06-13-2007, 01:45 AM   #2 (permalink)
CL30131 is on a distinguished road
Maybe something wrong with your "warm-up" (automatic choke) unit. I used to have a 518i with similar issues, especially when cold. Although mechanics wanted to replace it at a cost of half the cars value I never did and just lived with the problem. Does he back-fire during startup as well?
CL30131 is offline   Reply With Quote
Old 06-14-2007, 11:51 PM   #3 (permalink)
ozarkmark's Avatar
Nope, no backfires. Not even a puff of smoke. It is really perplexing but your issue sounds similar. I have an good indy shop I may take it to and see if they can diagnose - if it becomes a regular occurrence. It happens so seldom that I am not really woried about it just yet. I thought I would floa this out there and see if anyone else had something similar.
It may be just a weak battery...it sounds like the starter is sort of weak whenever this happens. I'll kep everyone posted.
Thanks!
Old 06-15-2007, 04:49 AM   #4 (permalink)
Hmm, well the battery will take a dip when starting takes longer than usual. Just check the acid levels if you wanna be sure. If it's not a regular thing I won't even worry. Regular service/maintanance of the obvious components to keep them in proper working order always reduces the search for a problem. Difficult start-up in my case was many times related to the distributor. I seemed to push the car to hard , as I went through a distributor and rotor every two years...
Old 06-16-2007, 01:40 AM   #5 (permalink)
could be a idle control valve or possibly even the beginning of failure of the cam position sensor.
Either of those will eventually set off a check engine light, though.
Old 02-21-2010, 09:22 AM   #6 (permalink)
chraw1 is on a distinguished road
any info the 525i se 2000 started the morning then 20 min later stop and try restarting no joy turns and fires but dies striaght away
chraw1 is offline   Reply With Quote
Old 02-21-2010, 11:28 AM   #7 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
I suggest you start a new thread so you do not cloud the issues of the fellow that started this thread :-)
Old 02-21-2010, 11:34 AM   #8 (permalink)
Arrow
your symptoms point to an air &/or fuel problem.
1) when was last tune-up? i.e. change of fuel and air filters - that would be a good place to start.
2) Dirty Idle Air Control motor & the MAF sensor, will also do that. A good carb cleaner spray on these two components might be in order.
** if those 2 don't work, then we'll delve into the more complicated issues :-)
Good Luck
starting problems (weird) helm 3-Series (E36) 10 02-21-2006 05:04 PM
1990 735i Starting Issue Kordellt 1,6,7,8 - Series and Mini Cooper 0 04-14-2005 08:17 AM
Need Help, Odd Starting Issue theogill 3-Series (E36) 0 09-24-2004 07:42 PM
Weird cabin blower issue kestrel325is 3-Series (E36) 3 07-22-2004 04:51 PM
