water pump 528e - BMW Forum - BimmerWerkz.com
Old 01-23-2004, 05:28 PM   #1 (permalink)
csd
csd is an unknown quantity at this point
I have an 86 528e with a leaky water pump. The book says to strike the nut quickly on the fan to loosen it, which seems impossible(ive tried several times) so any suggestions would be appreciated. Thanks ghead s..
csd is offline   Reply With Quote
Old 03-16-2006, 05:40 AM   #2 (permalink)
mehumming's Avatar
mehumming is on a distinguished road
Send a message via AIM to mehumming Send a message via Yahoo to mehumming
ha
mehumming is offline   Reply With Quote
Old 03-16-2006, 07:01 AM   #3 (permalink)
mehumming's Avatar
try striking the nut in the opposite direction ???????????
Old 03-16-2006, 07:09 AM   #4 (permalink)
mehumming's Avatar
normally with a solid rod of steel placed on the nut , stricking the rod with sharp blow ( HAMMER) will snap the locking position and allow the left hand thread to be free.. other wize try a cold chisel on left hand side of nut striking around the nut should come off nice and easy just spin the fan... left ways
Old 03-20-2006, 03:46 PM   #5 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Get a wrench the same size as the fan nut, place on nut, strike wrench toward the drivers side, fan should come loose
Come see me at MySpace
Old 03-29-2006, 06:33 AM   #6 (permalink)
mehumming's Avatar
hot fans often tight
yeah thats i was try to say , wrench, get the wrench onto it. theres a special spanner available from automotive tool stockist that is slightly thinner than normal spanners makes things a Little more comfortable to loosen.
left hand threads on those fans i am most certain of that
Old 03-29-2006, 06:32 PM   #7 (permalink)
325isBaby's Avatar
Car: 2005 330xi
You don't actually need the spammer tool (most of the time) I'm a girl and I get the fans off EVERY time with a smack with the hammer....food for thought
Old 03-30-2006, 10:44 AM   #8 (permalink)
Kyytsis's Avatar
Kyytsis is on a distinguished road
Left hand threads, yes.
Should come off easily as desribed above. You may want to ask a friend to help. (S)he can lock the waterpump pulley with a rather long screwdriver and then getting the blover finns off should be piece of cake using "spammer" and hammer.
In e28 sooo easy, as the hood opens from the latter edge.
- Ville
Kyytsis is offline   Reply With Quote
Water Pump TeeUp 3-Series (E36) 23 11-26-2007 07:03 AM
How To Stop The Water Pump KILOCHARLIE 3-Series (E36) 8 08-03-2005 07:09 AM
Question On Water Pump Explosion Phil137 3-Series (E36) 5 09-23-2004 10:42 AM
Leaky Water pump or the Themostat Housing RedBeemer95 3-Series (E36) 12 08-21-2004 07:13 PM
water pump. HELP! viali8 3-Series (E21, E30) 2 05-30-2004 04:50 PM
