vibration durring acceleration - BMW Forum - BimmerWerkz.com
Old 12-07-2009, 07:59 PM   #1 (permalink)
wayne_0 is on a distinguished road
Does anyone know how to fix my car? It starts and idles fine. When I step on the gas, it vibrates, does matter how fast i am going, when i coast, it goes away! please help
wayne_0 is offline   Reply With Quote
Old 12-08-2009, 02:52 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
It would help if you specified what model, year etc.
Old 12-08-2009, 02:56 AM   #3 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
carguy13 is on a distinguished road
has your car ever been in a bad wreck? salvaged? anything like that?
carguy13 is offline   Reply With Quote
Old 12-09-2009, 10:27 AM   #4 (permalink)
no accidents or anything, from what i researched on the internet, i am thinking that i need to replace the cv joints or boots ? Not sure but the vibration is only when i step on the gas. when i coast or am just at idle the vibration is gone!
Old 12-09-2009, 10:28 AM   #5 (permalink)
this is my 2002 525I sedan having the issue
Old 12-09-2009, 02:27 PM   #6 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Check your drive shaft
LOS
Old 12-09-2009, 02:46 PM   #7 (permalink)
i checked the drive shaft, it appears there is some play where the drive shaft attatches to the cv joint. i am going to look under my 3 series when it gets home to see how much play is in that one. Hopefully i can change out the cv joint without going to the dealer. They wont even look at my car for under 150 bucks!
Old 03-02-2010, 06:32 PM   #8 (permalink)
Car: 2003/BMW/325xi
onehrs is on a distinguished road
Wayne 0, did you ever fix it? if yes, what was the problem?
my 325xi sounds like it has a same problem like the one you r describing.
mine also shakes when accelerating in any gear, but not al the time...
onehrs is offline   Reply With Quote
Old 03-02-2010, 07:07 PM   #9 (permalink)
525 I is fixed
Thanks everyone for all the help and articles. Turns out that my problem was the drive shaft. Apparently there is a gasket that holds packed in grease on the side that is attached to the rear of the car. It was completely dry and ruined my drive shaft. I purchased an aftermarket one (came with new gasket and grease installed by powertrain) from powertrain industries, 3336 spring Stuebner Suite S, Spring TX 77389. It was about 400 plus a 75 dollar core return credit - so like 325. It was hard to replace. Just had to drop the exhaust about a foot. I was able to get to all the bolts. Out with the old and in with the new in about 2hours. Now that i know what i am doing it should really only take about an hour. Good luck , hope this helps someone else!
Old 03-02-2010, 07:38 PM   #10 (permalink)
Glad it's sorted, thanks for sharing the answer.
Old 03-02-2010, 07:55 PM   #11 (permalink)
Car: 2003/BMW/325xi
thanks, i will have this checked tomorrow on my car
Strange occasional vibration at acceleration CrazyIsland 3-Series (E46, E90) 4 12-10-2009 02:00 PM
erratic tachometer & engine vibration on 1st gear acceleration Superbug 3-Series (E46, E90) 2 04-06-2009 02:48 PM
525i Vibration under Acceleration BimmerChef 5-Series (E12,E28, E34, E39, E60) 6 12-04-2008 09:39 PM
'95 525i 230k, lumpy acceleration&vibration raborg36 5-Series (E12,E28, E34, E39, E60) 4 10-21-2005 12:16 AM
Acceleration BMWLotAttendant 3-Series (E46, E90) 9 08-26-2004 11:10 PM
