Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 09-03-2003, 09:23 PM   #1 (permalink)
Photos: 0
Blackdog is an unknown quantity at this point
I need some advise. I just bought a 1995it and it had a bad vibration at speeds between 55-60. I got a alignment done and a rotate and balance. Well the problem is still there but not as bad. I can feel it in the steering wheel. Just a slight shake. What should I do next?
Blackdog is offline   Reply With Quote
Old 09-03-2003, 09:27 PM   #2 (permalink)
Ski
Sheer Driving Pleasure
Ski's Avatar
Photos: 0
Ski is an unknown quantity at this point
You know this guy??
http://www.bmw-forums.com/forum/index.php?...?showtopic=3184
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
'94 325is Not so loaded..
Ski is offline   Reply With Quote
Old 09-03-2003, 09:29 PM   #3 (permalink)
Photos: 0
No. I don't know that guy.
Old 09-03-2003, 09:31 PM   #4 (permalink)
Ski
Ski's Avatar
Photos: 0
Ok..does it happen when you brake?? if so your rotors are warped..
Also have your control arms and bushngs checked along w/ ball joints..
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
Old 09-08-2003, 09:07 PM   #5 (permalink)
Photos: 0
Exclamation
I have had the wheels balanced and the front end checked out. I have had an alignment and there was still a slight shake in the wheel. You will not believe this but the only thing that reduced it almost to a stop. I took the front wheels off of the car and went into the garage and found my electric sander. I put some rough paper on it and started to sand some of the rust that is on the hub and the in side of the wheel where the rim fits against the hub. This is what took almost all of the shake out. It still shakes but you can barely feel it.
Old 09-08-2003, 09:21 PM   #6 (permalink)
Ski
Ski's Avatar
Photos: 0
You running Conti's??
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
Old 09-09-2003, 03:30 PM   #7 (permalink)
Photos: 0
No. I have all season H rated Daytons.
They were on the car when I bought it.
They look like new tires.
Old 09-15-2003, 11:37 PM   #8 (permalink)
Photos: 0
Smile
Well I found out from a tire guy that BMW ‘s need a certain tread on the tires. BMW’s suspension is so fined tuned that it is only happy with expensive tires. He told me not to rotate my tires and also that my tires are out of round. Now you know the rest of the story. ghead
Old 09-23-2003, 06:24 PM   #9 (permalink)
alanh's Avatar
Photos: 0
alanh is an unknown quantity at this point
Send a message via AIM to alanh
um thats not right why would you not rotate the tires? my family has three and we rotate them all... i have many credable sources better than some tire guy.
Self-Proclaimed Genius
alanh is offline   Reply With Quote
Old 09-23-2003, 06:33 PM   #10 (permalink)
6th Gear Member
lwebb12's Avatar
Car: 2000 M5
Photos: 0
lwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond repute
Send a message via AIM to lwebb12 Send a message via Yahoo to lwebb12
i am running Kumho's and they arent so called "expensive tires" the tires you have may be screwed though. I am not able to rotate my tires dude to my wheel configuration.
Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
lwebb12 is offline   Reply With Quote
Old 09-23-2003, 08:49 PM   #11 (permalink)
Photos: 0
To the guy that said that he rotates tires on his BMW. I hate to tell you this but BMW will tell you the same thing. You can also read this in Bentleys service manual.
Old 09-25-2003, 12:45 PM   #12 (permalink)
EXtech's Avatar
Photos: 0
As it has already been said, BMW's are extremely sensative to tires because they are so fine tuned. Some tires are not made to the same tolerances that others are and this slight out-of-roundness or imperfection will make all of the difference in the world. This is why companies like Hunter, who make most of the tire mount and balance machines and are the industry leader, they have implicated a new step to balancing tires in the last few years. It's called a Road Force variation detection. Basically what the machine does is it puts a real-life simulated "road force" load on the tire to check for out of roundness and variations while balancing it. The variations can stem from pot holes in the road, improper or less than perfect manufacturing processes etc. Not rotating your tires at the recomended intervals will cause uneven tire wear that these bmw's will object to. BMW makes service recomendations for a reason. They design these cars so they know what maintenance should be done and for what reasons. Years before any of us ever see these cars, the BMW "scientists" have tested these cars and tires and engines etc. under the same real world conditions that we subject them to. This combined with the design process determines when and what you should do to your car in order to maintain OE performance. Part recomendations, whether it be tires or brake light bulbs, are made for a reason and that is so the bmw owner can maintain the intended feel and performance of his or her car, the same as it was the day it rolled off of the assembly line.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 10-18-2003, 02:19 PM   #13 (permalink)
Photos: 0
hartzj is an unknown quantity at this point
I may be wrong, put I thought the reason you do not rotate is because a tire develops a "footprint" at the position it is in, (i.e. front left, rear rihgt, etc.) although they may wear unevenly if not rotated, the tire will perform better and is not likely to develop odd sounds if left in one place. My service manual suggests not to rotate. 1998 528i.
By the way I'm new to this forum and enjoying it!
hartzj is offline   Reply With Quote
Old 10-18-2003, 02:26 PM   #14 (permalink)
Photos: 0
I've got a problem, that my instincts tell me is the front wheel bearing. WhenI'm driving on the highway I hear medium to highpitched whine towards the front left of the car. It is not related to RPMs because if i shift to neutral it remains. It gets louder when I take a right turn and quieter when I take a left turn. I have not done anything yet, but will check the bearings today.
HELP?!!
Old 10-18-2003, 06:56 PM   #15 (permalink)
Photos: 0
Well I took the tire off and it is definitely the front left wheel bearing. It's loud when I turn it and the right one is not. Looks like a pretty easy job four bolts on the back of the bearing. I was about to price them, when I realized I still have about nine months left on my Certified warranty. Hope is't covered. I'll call on Monday!
vB code is On
E46 328i '00 Steering vibration. Can't fix. HELP ! guilherme128 3-Series (E46, E90) 6 08-04-2005 12:09 PM
Ya...another Vibration Question... doughnutboy 3-Series (E36) 3 06-02-2005 02:09 PM
Need Help On Front End Vibration ye12 3-Series (E21, E30) 5 11-16-2004 12:20 PM
'92 750il steering wheel vibration jcsmtlsd 6,7,8,X,Z - Series and Mini Cooper 0 08-31-2004 04:30 PM
HELP! - Engine/Tranny Vibration & Engine Light Fangs 3-Series (E46, E90) 10 01-24-2004 08:30 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
