Recently replaced upper control arms - torqued per instructions with the front end loaded, etc.
Now I have a shimmy while braking after only a few thousand miles which is much too soon for the bushings to be bad again (hopefully). Any other reason for a bad front end shake while braking? Rotors seem fine - it is not a braking pulse type of thing.
Any hints welcome! If it can only be the bushings, i'll buy a better set next time!
It is a 95 540/6
It is a 95 540/6
