Uphill struggle - BMW Forum - BimmerWerkz.com
Old 07-17-2009, 09:52 AM   #1 (permalink)
Cas
Cas's Avatar
Car: 95/6 525td
Cas is on a distinguished road
Send a message via MSN to Cas
Unhappy Uphill struggle
I loned my 96 525td to a mate and when i got it back it cuts out going uphill when the fuel gets to just above the fuel warning light limit,i was thinking the feed pipe in the tank,but would like to explore other possibilities before i have to drop tank,any advice please.
Cas is offline   Reply With Quote
Old 07-17-2009, 10:04 AM   #2 (permalink)
How recent is the last fuel filter change? Could the injectors need cleaning?
Old 07-17-2009, 10:12 AM   #3 (permalink)
Cas
Cas's Avatar
Car: 95/6 525td
just done a full service when i bought it 6 month ago,started cutting out about 6/7 weeks ago,it only cuts out when the fuel gets to the red light level,just above the reserve,it starts again straight away as soon as i get on level ground.
My little cherub
Old 07-17-2009, 10:27 AM   #4 (permalink)
Maybe the fuel pump(s) are playing up a bit. Are you confident with the fuel pressure regulator?
Old 07-17-2009, 10:34 AM   #5 (permalink)
Cas
Cas's Avatar
Car: 95/6 525td
To tell you the truth i'm not sure what it could be,i've been fixing cars for 20+ years and bmw's are not a car i have had any contact with except driving them,aside basic service to mates.not even sure how i would check the regulator.
i'm not a mechanic,just self taught
My little cherub
Old 07-17-2009, 11:42 AM   #6 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
I would firstly say its a bad idea to keep running it that low, secondly when you are going up hill with such low fuel in the tank it all runs to the rear of the tank so the pump is just sucking air, also your sender in the tank may not be calibrated correctly giving a false reading, so when it comes on red light you may only have 1 gallon as opposed to 2.
Just a thought and good advice.
Old 07-17-2009, 05:34 PM   #7 (permalink)
abhicary is on a distinguished road
I think you will have to change the injectors. I am not sure, but it may be the problem.
BMW E46 2008 BMW Lights
abhicary is offline   Reply With Quote
Old 07-18-2009, 01:22 AM   #8 (permalink)
Cas
Cas's Avatar
Car: 95/6 525td
Thanks guys,looks like its an elimination process,i think i'll start with what i think is most likely,in tank feed,just cant believe on a 96 bmw you have to drop the tank to get to pump/guage.That said,my fuel guage does'nt move between red light-about 15 litres,so have to guess this by my trip meter,also,i very rarely let it go to below 1/4 tank,if i put my foot down,the guess work goes out the window.
I get about 35-40 mpg driven sensibly,not even sure if this is good,this is my first ever diesel,once again,thanks.
My little cherub
car surges at 50mph uphill? Nathan300 5-Series (E12,E28, E34, E39, E60) 2 06-10-2004 01:49 PM
