U Joint - BMW Forum - BimmerWerkz.com
Old 04-11-2005, 09:34 PM   #1 (permalink)
Rkhoubian is an unknown quantity at this point
Hi everyone
I have E39, 1997 with manual transmition.
Problem:
When I start moving there is some metal noise coming from. sounds to me, transmition. Also when changing from 1 to 2 speed.
From my past expirience with another car , not bimmer, sounds like U-Joint.
Does anybody have any comments
Thanks a lot
Rkhoubian is offline   Reply With Quote
Old 04-12-2005, 12:48 PM   #2 (permalink)
what about in reverse? if it doesn't make the noise in reverse it could be your tranny.
it could be the carrier bearing becasue there isn't traditional u-joints on your car there are jsut rubber bushings.
Old 04-12-2005, 01:20 PM   #3 (permalink)
Prop shaft and gearbox faults are uncommon on BMW I'd look at the clutch first and then the gearbox rear mounts especially if you got an oil leak.
Old 04-12-2005, 06:18 PM   #4 (permalink)
Some thing specific in clutch or just change whol system?
Thanks
U Joint Going Out Help!!!!!!!!! erbeman 3-Series (E46, E90) 5 10-15-2008 09:53 PM
Ball Joint Replacement irish 3-Series (E21, E30) 5 05-21-2005 12:47 AM
Rear Ball Joint Replacement Eric S. 5-Series (E12,E28, E34, E39, E60) 1 04-04-2005 11:50 AM
Control Arm Ball Joint Renewal Foley 3-Series (E21, E30) 9 09-27-2004 07:33 PM
