Turns over and starts for 5 secs then dies - BMW Forum - BimmerWerkz.com
Old 02-15-2011, 06:17 PM   #1 (permalink)
Brandon209 is on a distinguished road
i have a 525i need help trouble shooting any suggestions?
Brandon209 is offline   Reply With Quote
Old 02-16-2011, 07:50 AM   #2 (permalink)
theluis's Avatar
Car: 1995 BMW 325i 5 Speed
theluis is on a distinguished road
Hmmm when it does start does it have oil pressure? If it doesn't it may be the actual car turning itself of for protection...
theluis is offline   Reply With Quote
Old 02-16-2011, 03:46 PM   #3 (permalink)
pagerussell is on a distinguished road
sounds like a vacuum pressure problem to me. The car isnt getting enough oxygen and is literally choking to death. What year is your 525?
I had an e34 535 that I replaced the headgasket on, and when I put the throttle body back on I did not notice it was cracked. This caused it to lose intake pressure and die pretty quick after startup. You can get a smoke machine to test if you have any holes in your intake system (but remember to open the throttle body flap when you test!)
pagerussell is offline   Reply With Quote
Old 02-17-2011, 02:25 PM   #4 (permalink)
Phillip Biggs is on a distinguished road
I'm not familiar with the 5 series, mines a 3 series E46, but I had a very similar problem. Mine turned out to be a faulty mass airflow sensor (MAF) that on the 3 series is immediately after the air filter.
I'd gone through a lot of other checks first. Checking there's fuel getting through (after the engine has stalled take the cover off the little nozzle on the fuel rail and press down on the valve - it's like the tyre valve - but keep your head out of the way. If there is enough fuel getting through it will spurt out under high pressure - if not there may be a problem with the pump / fuel filter not getting enough fuel to the engine. All that's assuming the 5 series has a fuel rail like mine etc)
My service was also due so I replaced the spark plugs, air filter etc as they had to be done anyway. Eventually I bought a kit to read the codes from the car's computer and that identified the MAF as the problem.
It was already on the list of things to try but as they are very expensive I didn't want to buy one on the off chance. p.s. buy the proper BMW part. I bought a cheaper 3rd party one and that didn't work leading me to think it wasn't the MAF and calling in the garage for a tow and repair. They put a BMW one on and fixed it.
Phillip Biggs is offline   Reply With Quote
Turns over fine. Sometimes starts, sometimes doesnt. mrmojo37 3-Series (E36) 3 12-13-2008 03:16 AM
Starts instantly, then dies luckycat 3-Series (E21, E30) 5 01-07-2006 07:30 AM
Starts And Dies Bertman 3-Series (E21, E30) 2 10-10-2004 05:04 PM
starts then dies....very rough low idle help!! pagz 5-Series (E12,E28, E34, E39, E60) 5 07-09-2004 02:04 PM
'87 325 turns off when coming to stop, starts afte plasmaboy 3-Series (E21, E30) 7 06-02-2004 06:15 PM
