Trunk Wont Unlock With the Button - BMW Forum - BimmerWerkz.com
Old 03-27-2009, 04:47 PM   #1 (permalink)
Car: 2002 530i Sports/Prem Pkg
longrob is on a distinguished road
I really appreciate this forum. Has saved me lots of time and $$.
My latest problem:
My trunk unlocks with my key, but when I push the button under the dash, it no longer does anything. Any ideas why? Fuse?
-Rob-
longrob is offline   Reply With Quote
Old 03-27-2009, 05:46 PM   #2 (permalink)
The fuse would be my first look.
Old 03-27-2009, 05:53 PM   #3 (permalink)
To clarify, my trunk unlocks with the button on the key, not that I have to put the key into the trunk lock.
Old 03-29-2009, 05:10 PM   #4 (permalink)
mconerly is on a distinguished road
I had this problem, the gasket around the button had gotten displaced and was preventing the button from being pushed in all the way. I was able to fix it by using tweezers and needlenose plires to pull the stuck part of the gasket back out. Might be what is causing your problem and explains why the key button still works.
mconerly is offline   Reply With Quote
Old 03-30-2009, 01:10 PM   #5 (permalink)
Problem turned out to be the truck lock was in the valet position. The key can be removed in either position, ie, horiz is valet, vertical is normal. Wife did it!
driverside rear door wont unlock swiftkraft 3-Series (E36) 0 05-02-2008 10:21 PM
95 318ic wont start, egine wont turn over. (couple cold days) vic318ic 3-Series (E36) 2 02-05-2007 10:00 AM
95 740il trunk wont open blaze132 1,6,7,8 - Series and Mini Cooper 1 06-04-2006 08:00 PM
trunk wont open kc740i 1,6,7,8 - Series and Mini Cooper 6 02-18-2006 03:06 PM
trunk button petch 3-Series (E36) 1 01-13-2004 11:15 PM
