Trouble starting and battery light on in dash - BMW Forum - BimmerWerkz.com
Old 08-10-2011, 12:47 PM   #1 (permalink)
dzuvia9 is on a distinguished road
1990 525i
I just had a new head unit installed and I was curious if that could be causing the batter/electrical problems.
Whenever I do eventually get the car to start, the radio will turn on and when I put anymore of a load on the system, like lowering the windows, or lights, or defrost, the head unit will turn off and it seems like the car is going to give out.
The lights seemed extremely dim the other night and even the check battery light seemed to fade in and out with my decelerations and accelerations.
Before the new head unit, the battery did have problems going flat occasionally, put it almost always started and never had electrical problems.
Alternator? Voltage regulator?
dzuvia9 is offline   Reply With Quote
Old 08-10-2011, 02:00 PM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Like you said, alternator ! Or maybe a mickey-mouse ground/earth issue !!
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 08-12-2011, 10:49 AM   #3 (permalink)
Well, I had both the alternator and the battery checked. They are both good.
So, Dabsy, our only other option is a mickey-mouse ground/earth issue!!!
Or, maybe a voltage regulator? Not sure, leaning toward mickey-mouse.
Old 08-12-2011, 01:58 PM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Generally speaking, the alternator deals with "regulation" ...
I would firstly, check the head-unit installation and work back from there (Cautiously avoiding Minnie Mouse)!
Maybe put an ammeter on the battery and test it with and without the key in (on acc)...
HTH
Eso es todo!
BMW Part Market
New Member ?
Old 08-12-2011, 05:48 PM   #5 (permalink)
The HU install was a complete re wire. My BMW did not have the option for a harness install for the radio. We decided to completely avoid the common ground setup (and Goofy while we were at it) and just wired all the speakers to the HU directly. The guy even took out the old factory amp.
All the connections were soldered and were well done.
Looks like I am going to have to go diggin'
Old 08-13-2011, 04:30 AM   #6 (permalink)
njtl001 is on a distinguished road
HTH
You are so interesting,
To be happy! That cutting blade & Circular Blades
njtl001 is offline   Reply With Quote
Old 08-13-2011, 06:53 AM   #7 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Thank you !!
Eso es todo!
BMW Part Market
New Member ?
Old 08-19-2011, 04:50 PM   #8 (permalink)
So I put in the new voltage regulator, the car only seems to be running worse. The radio starts to short out more and the car itself seems like it is giving out, only to suddenly jerk back.
Old 08-20-2011, 11:02 AM   #9 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Deffo a BAD connection mate... Looking like it's throwing the new reg out too !!
Eso es todo!
BMW Part Market
New Member ?
starting trouble tim96 3-Series (E21, E30) 24 04-03-2010 05:37 AM
Starting trouble tim96 3-Series (E21, E30) 4 09-04-2009 05:41 PM
Some trouble starting. e30dream 3-Series (E21, E30) 7 01-11-2007 09:13 PM
Trouble Starting Old_School_Bimmer 3-Series (E21, E30) 4 07-29-2004 03:40 PM
Battery Light on dash cluster?? LuvDaBimma's 3-Series (E36) 1 06-24-2004 11:51 AM
