Trouble with Pedal Box - BMW Forum - BimmerWerkz.com
Old 10-10-2003, 01:30 PM   #1 (permalink)
Mach 5's Avatar
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
The pedal box on my friends 87 535is broke just in front of the pivot for the clutch pedal. ghead I was wondering if this was a common occurance and where a replacement part might be obtained. I am a bit shy about obtaining a used part if this is a common issue. I only want to replace this part once given the amount of time that I am going to have to spend under the dash. Thanks for the info on parts and any advice to make the job easier is appreciated.
Ben
"It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife.
Mach 5 is offline   Reply With Quote
Old 10-11-2003, 03:32 PM   #2 (permalink)
dykaar's Avatar
dykaar is an unknown quantity at this point
BTDT. Remove the car from the pedal box and have strip of metal welded over the broken support. Paint it black and reassemble. I paid a local guy $20 CDN on a saturday to weld it up.
-doug
85 535
86 951
94 855
-doug
85 535
<a href='http://www.pcaucr.org/pcaucr/discussion.nsf/BabyPictures/62243cdebc3e5aad852568bd007e9093' target='_blank'>86 851</a>
94 855
dykaar is offline   Reply With Quote
Need help with E34 accelerator pedal m3driver97 5-Series (E12,E28, E34, E39, E60) 4 10-03-2005 10:17 AM
Clutch Pedal Mount Tweaked 325eXTATIC 3-Series (E21, E30) 5 08-22-2005 03:55 PM
'94 318is Sticky Accelerator Pedal ultraviolet353 3-Series (E36) 8 01-25-2005 12:26 PM
Clutch pedal squeeking on release of pedal theogill 3-Series (E36) 7 09-14-2004 10:01 AM
