Transmission Problems ZF5HP24 - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 09-25-2013, 10:03 AM Thread Starter
c_zellars is on a distinguished road
I have rebuilt my transmission (ZF5HP24 01 E38) and am still having some issues.
I purchased the Master Rebuild kit from Rockauto.com for $400.00 and it came with everything I thought that I needed. I replaced the steels and clutch disks and seals o-rings. I took apart the valve body and cleaned it (but did not have time available to take apart each valve where the springs reside)
So I finished putting the transmission back in the car and I am experiencing the following issues:
(These were a couple of the issues I had before I rebuilt the transmission)
1. The DSC light stays on.
2. When I come to a stop the transmission disengages and takes around 5 seconds to kick in (engage). If stopping from a higher speed it takes even longer to engage. I have topped the fluid off twice (following procedures I found on E38.org) and changed the transmission filter from the filter that came from with the rebuild kit to a Filtran Filter and the issue remains. Seems worse when turning a corner.
c_zellars is offline
post #2 of 3 (permalink) Old 10-06-2013, 05:53 PM
4DoorWhore
Lord Vader's Avatar
Quoted: 2 Post(s)
The DSC light could be a failed sensor. Have the OBD II system scanned for trouble codes as that will hopefully indiciate why the DSC light is on. Its an automattic transmission correct? I would look at the torque converter as to the reason its not properly engaging.
And Follow Me on Instagram @E36M52
Founding Member of the Canyonrot Club! Paint Code #343
| OE M3 Bumper | M3 Mirrors | Max Velocity GTR Lip | Euro ZKW Projector Headlights | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Lord Vader is offline
post #3 of 3 (permalink) Old 11-18-2013, 07:46 AM Thread Starter
Problem solved
I know this is a bit late but the issue was resolved by adding fluid. The standard method of adding fluid with car off the ground at certain temp while shifting thru gears did not work for me.
I added a quart more after it started overflowing from center plug and it shifted better. I added another half quart thereafter and even better.
The DSC light still comes on but I will work towards investigating in the near future.
740il ZF5HP24 no reverse after I rebuilt it 20ramper 1,6,7,8 - Series and Mini Cooper 4 02-05-2010 09:58 AM
Help - transmission problems ! avneet07 5-Series (E12,E28, E34, E39, E60) 17 06-08-2009 08:45 AM
transmission problems slick8541sniper@hotmail.c M-Series (M1, M3, M5, M6) 0 11-18-2006 03:54 PM
Transmission Problems ben_t 5-Series (E12,E28, E34, E39, E60) 1 01-18-2005 07:43 PM
Transmission problems sb93lx50 5-Series (E12,E28, E34, E39, E60) 0 09-29-2003 08:24 PM
