Transmission issue or brakes - BMW Forum - BimmerWerkz.com
Old 02-12-2013, 09:44 AM   #1 (permalink)
SUPER_SPORT's Avatar
Car: 2009 X3
SUPER_SPORT is on a distinguished road
94 540i: Feels like the brakes ar on when trying to move forward. changed transmission oil and filter. Still having issues. Drove fine after oil change. Then second test drive the car felt like the brakes are full on. Could there be a brake issue versu a transmission issue?
SUPER_SPORT is offline   Reply With Quote
Old 02-12-2013, 06:15 PM   #2 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Brakes are cheaper to fix so start with that. If possible remove the wheel and look at the brake pads. Are they up against the rotor? Is the rotor tough to turn? Again if possible, remove the caliper. Inspect the pistol seal. If the seal is damaged or worn mositure can get into the piston creating rust and causing it to sieze.
Best way to determine if you have a transmission related issue is to have the OBD system scanned for trouble codes. If their is a problem with the tranny it will store a DTC, even if it doesnt trigger a CEL.
Click HERE to see my E36 Blog
Old 02-12-2013, 07:53 PM   #3 (permalink)
Car: 2009 X3
Hello Lord Vador,
Thank you for your reply. So I just jacked up the back of the car. With the parking brake off the wheels only turn forward and not in reverse, in all positions except park. I would think it would go in both directions in neutral. Wheels turn freely with normal drag.
525i transmission issue BuckeyeRealtor New Members Check In 2 09-30-2011 02:25 PM
97 BMW 540i Transmission Issue chaos0221 5-Series (E12,E28, E34, E39, E60) 4 11-29-2009 05:30 AM
1984 BMW 633csi Transmission Issue... kotakhan New Members Check In 0 02-19-2009 06:34 PM
Hello Everyone:)May I ask for assistance on possible transmission issue?Thank you! jetairliner 5-Series (E12,E28, E34, E39, E60) 0 09-09-2008 07:52 AM
Brakes Issue fushuman 3-Series (E36) 2 12-18-2004 10:51 PM
