Transmision fluid change - BMW Forum - BimmerWerkz.com
post #1 of 2 (permalink) Old 09-05-2003, 09:35 AM Thread Starter
Blackdog is an unknown quantity at this point
Thumbs up
Does anyone know if I could change my owne trans fluid on my owne?
The 325I that I had, I was told that I would have to take it to a machanic and they would have to use a special machine to change the fluid. Does anyone know?
Blackdog is offline
post #2 of 2 (permalink) Old 09-05-2003, 01:37 PM
DesmoBob's Avatar
manual transmission:
i am ignorant of the specifics of the 5 series, but the principles should be the same as e36 which i'm familiar with.
drive the car a few miles to warm up the tranny. jack up the car on jackstands (must be level). remove the FILLER bolt first (important), then the drain bolt to drain the fluid. you MUST remove the FILLER bolt first, otherwise if you remove the drain bolt first and discover the filler bolt is frozen, you are basically stuck with no way to refill.
after draining, replace drain bolt (with new crush washer if present). use your handy $2.99 hand pump to put new fluid in the filler hole until it starts to overflow. replace filler bolt (with new crush washer if present).
automatic tranny
i do not know off the top of my head. have to check bentley. perhaps this is where they require the "special machine"?
DesmoBob is offline
ATF oil? sanjose 5-Series (E12,E28, E34, E39, E60) 3 02-01-2009 02:35 AM
Manual Tranny Fluid Change Beemert 3-Series (E36) 2 05-03-2005 12:13 PM
Changing Auto Transmission Fluid billB 5-Series (E12,E28, E34, E39, E60) 8 10-11-2004 10:12 PM
When to change "lifetime" tranny fluid LloydM 3-Series (E36) 9 08-31-2004 04:38 PM
How to change Tranmission fluid ???? mnguyen11111 5-Series (E12,E28, E34, E39, E60) 6 08-22-2004 01:50 AM
