Trans Fluid - BMW Forum - BimmerWerkz.com
Old 12-11-2004, 12:35 PM   #1 (permalink)
cozmo720 is an unknown quantity at this point
I have 1991 525i what kind of trans fluid do I use?
cozmo720 is offline   Reply With Quote
Old 12-11-2004, 01:02 PM   #2 (permalink)
billB's Avatar
[snapback]247993[/snapback]
Cozmo
It looks like you have GM transmission on your car (DOUBLE CHECK IT THOUGH) if so it is listed as THM-R1 (A4s 310R)
Unical Dexron lll ATF
Castrol Dexron lll Mercon
Capacity: 8.8 liters with torque, 7.8 without it. Just make sure it is not a ZF tranny.
good luck
Old 12-11-2004, 01:57 PM   #3 (permalink)
Originally posted by billB+Dec 11 2004, 01:02 PM--><div class='quotetop'>QUOTE(billB @ Dec 11 2004, 01:02 PM)</div><div class='quotemain'><!--QuoteBegin-cozmo720@Dec 11 2004, 07:35 PM
Cozmo
good luck
[snapback]248012[/snapback]
[/b][/quote]
Where do I check for it ?
Old 12-11-2004, 02:08 PM   #4 (permalink)
billB's Avatar
usually a sticker on the tranny itself
1999 Z-3 Auto Trans Fluid Change leachmj 1,6,7,8 - Series and Mini Cooper 2 02-08-2005 01:23 PM
Changing Auto Transmission Fluid billB 5-Series (E12,E28, E34, E39, E60) 8 10-11-2004 09:12 PM
Mobil 1 trans Fluid Laker 3-Series (E36) 1 08-18-2004 11:55 AM
740il Auto Trans Fluid tknesek 1,6,7,8 - Series and Mini Cooper 3 02-04-2004 08:12 AM
trans fluid Blackdog 5-Series (E12,E28, E34, E39, E60) 3 10-06-2003 11:13 PM
