Tranny fluid replacement - BMW Forum - BimmerWerkz.com
post #1 of 7 (permalink) Old 07-27-2008, 12:25 AM Thread Starter
harleyal is on a distinguished road
Unhappy Tranny fluid replacement
SOS! My husband is still trying to figure out how to replace the tranny fluid. He is aware that there is no dipstick, unlike GM's but now the question, how does one go about replacing the tranny fluid? Your help would be greatly appreciated.
Would appreciate a diagram if at all possible. Thanks
harleyal is offline
post #2 of 7 (permalink) Old 07-27-2008, 01:06 AM
W00T
Numark318i's Avatar
Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute
exactly what model?
what mileage.
auto or manual?
If the fluid has never been changed, and you are over 100 thousand miles dont change it if its an automatic. your tranny will shift hard and youll need a rebuild. Or it will be much more likely.
otherwise...the bottom of the transmission should have two bolts. One is the bleed screw and the other is the fill. You let the oil out one, and the other is to refill.
So once you empty, replace the screw and pump fluid into the other screw. (This one has a "tube" that let you know when you have filled it enough. because the fluid will start to leak out.)
This is an easy, maybe too simple explanation. So Let me know if you need more detail.
Numark318i is offline
post #3 of 7 (permalink) Old 07-27-2008, 01:29 AM Thread Starter
re tranny fluid replacement
You were asking about the make and year of this car. It's a 2000 540. Hubby says he can only find one plug on the bottom of tranny.
harleyal is offline
post #4 of 7 (permalink) Old 07-27-2008, 11:14 AM
darkhorse737's Avatar
Quoted: 2 Post(s)
i assume your car uses the ZF tranny...
*if you do change tranny oil, make sure your replacement is a manufacturer specified oil. Aftermarket(off the shelf ATF does not work on BMW transmission)
... if by chance you don't see a resemblance to the attached illustrations, then what is on your car is a GM tranny. Should that be the case, let us know and i will post the GM tranny drawings for you.
darkhorse737 is offline
post #5 of 7 (permalink) Old 07-27-2008, 06:27 PM Thread Starter
Tranny again!
Thanks for the diagrams but hubby still didn't recognize the location of plugs. Please send the other diagrams...GM hopefully that will give us the answer. Thanks again
harleyal is offline
post #6 of 7 (permalink) Old 07-27-2008, 07:30 PM
Quoted: 2 Post(s)
Smile
GM tranny...
post #7 of 7 (permalink) Old 07-29-2008, 10:20 PM Thread Starter
Thanks. I hope hubby figures this out. I miss my car!!!!
harleyal is offline
How to add tranny fluid beautyland 5-Series (E12,E28, E34, E39, E60) 14 06-26-2005 06:33 AM
Tranny Fluid OldGuy 3-Series (E36) 6 02-25-2005 10:06 PM
Tranny Fluid thr33series 3-Series (E36) 2 11-08-2004 08:58 PM
manual tranny fluid nycbmw325is Bimmer Talk/Motorsports Talk 1 08-09-2004 05:16 PM
Just changed my own tranny fluid Autotechnica 3-Series (E36) 7 04-30-2004 10:15 AM
