Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 11-08-2004, 07:54 PM   #1 (permalink)
Eric S.'s Avatar
Photos: 4
Eric S. is on a distinguished road
Thumbs up
Am replacing the spark plugs in my 1999 540i with the original-type NGKs listed in my owner's manual. Torque on spark plugs in aluminum heads is always important, but I cannot find that figure anywhere in my owner's manual. Does BMW think ALL of its owners would be helplessly dealer-dependent?!? used Even my Honda's owners manuals specified spark plug torque!
Anyone know the required torque for spark plugs in a 1999 540i? Please help, thanks!
<span style='colorurple'>Eric S.</span>
2006 Honda Odyssey EXL-RES
Eric S. is offline   Reply With Quote
Old 11-08-2004, 09:03 PM   #2 (permalink)
WindowPro's Avatar
Photos: 0
WindowPro is an unknown quantity at this point
[snapback]227027[/snapback]
Eric,
Not too sure on this... I checked around the forums and came up with 18 ft/lbs for a M3. This quote is from a rather experienced user on another forum --
"Sparkplugs are not stretch-to-yield fasteners. They can be removed and reinstalled at will. the torque spec is merely to ensure a good seal in the cylinder head. 18lbs/ft will be fine with or without antisieze paste on the threads. The car won't know the difference."
-Paul
Like I said...not too sure. Check around. Any help here Members?
Jim
<img src='http://img51.exs.cx/img51/2517/BMWFORUMSSIGNATURE.jpg' border='0' alt='user posted image' />[quote]GIRLS...GIRLS...GIRLS
WindowPro is offline   Reply With Quote
Old 11-08-2004, 10:26 PM   #3 (permalink)
billB's Avatar
Photos: 0
Eric s: This table should cover it all
Spark plug Correct Torque
10mm with Gasket…..8-11
12mm with gasket…..12-15
14mm with gasket…..19-22
18mm with Gasket…..20-23
18 mm tapered………..14-17
regards
Billb
Old 11-08-2004, 11:19 PM   #4 (permalink)
WindowPro's Avatar
Photos: 0
regards
Billb
[snapback]227113[/snapback]
Where do you come up with this stuff -- Genius!
Good Night.
Old 11-09-2004, 11:36 AM   #5 (permalink)
billB's Avatar
Photos: 0
WindowPro
I have my own data base and sometimes I HIT many times I MISS. I don't feel so bad about missing beacause our whole life is a learning process!!!
regards
billb
Old 11-09-2004, 11:48 AM   #6 (permalink)
WindowPro's Avatar
Photos: 0
Beautiful.
Access database? Excel?
Old 11-09-2004, 01:43 PM   #7 (permalink)
Eric S.'s Avatar
Photos: 4
regards
Billb
Bill - Thanks, I think that table is helpful, provided I can now come up with the diameter for the threads of my spark plugs. Putting 2 and 2 together, I've seen a number of 18 ft-lbs (which I thought was too low), so I guess my spark plugs' threads are 14mm and so my spec would be 19-22.
So now how much do I torque those two coil nuts (per coil) when I reinstall them? Anyone, anyone?
Old 11-09-2004, 03:49 PM   #8 (permalink)
Photos: 0
I'm a british BMW tech so you'll have to convert from Nm (newton meters) lbs ft
Most sprak plugs are 14mm thread and are 30Nm+/- 2 M power engine are 12mm thread and are 25Nm =/- 1 The 6mm thread (10mm across flats) nuts or bolts for the coils 10Nm Hope this helps
Old 11-09-2004, 07:42 PM   #9 (permalink)
Eric S.'s Avatar
Photos: 4
[snapback]227538[/snapback]
Hey "Bad Man" - you are a Good Man as far as I am concerned because that is precisely the data I was seeking! My Craftsman torque wrench dial is calibrated in both lb-ft and N-m, so there's no problem with the SI units!
I appreciate the help. Nevertheless, I am going to go ahead and purchase the ($$$) 2-volume bentley manual so that I'll soon be more of a knowledge SOURCE for such info, and less of an information absorber...
Old 11-09-2004, 07:46 PM   #10 (permalink)
billB's Avatar
Photos: 0
Eric S
The following (though old info.)may shed more light on the torque specs; check it out and let me know how you make out.
http://vinesauto.com/spa.htm
The above URL should do without any doubts!!
Regards
billb
vB code is On
Fouled Spark Plugs nookatee 3-Series (E36) 14 01-03-2006 08:07 AM
choice in spark plugs for 95 740i e38 kc740i 7-Series 2 11-13-2005 11:12 AM
BMW spark plugs Autotechnica 3-Series (E36) 36 08-18-2004 08:22 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
