Tires - BMW Forum - BimmerWerkz.com
Old 11-12-2004, 09:51 PM   #1 (permalink)
frank-e is an unknown quantity at this point
[FONT=Arial][SIZE=1][COLOR=blue] '02 540i, Sport Pkg. Will need new tires soon. OEM: 235/45ZR17 front (8x17 wheels); 255/40ZR17 rear (9x17 wheels). Have checked wheel wells - very tight.
1) Anyone had success with different sized tires?
2) Anyone recommend currently available tires in these sizes with symmetrical, non-directional tread patterns? Want to be able to move tires left-to-right, right-to-left to even wear. frank-e
frank-e is offline   Reply With Quote
Old 11-13-2004, 02:31 AM   #2 (permalink)
BMWLotAttendant's Avatar
BMWLotAttendant is an unknown quantity at this point
Send a message via AIM to BMWLotAttendant Send a message via MSN to BMWLotAttendant
Even ware?
The 5ers have the worst tire tread ware of all the BMWs combined. I think you better just find some tires that you like because even ware is your last concern.
BMWLotAttendant is offline   Reply With Quote
Old 11-14-2004, 04:44 PM   #3 (permalink)
Originally posted by BMWLotAttendant@Nov 13 2004, 03:31 AM
Even ware?
[snapback]229922[/snapback]
Thanks! I'm sort of "old school" and like the thought of flip-flopping (left to right to left) my tires. Your suggestion is about what I've come to - newer tires in the sizes I need that are non-directional are like the proverbial "hen's teeth!" I've actually had pretty even wear so far so I guess I'm lucky in that regard - I just hate the thought of dropping $200.00 or so to the dealer for a fresh alignment. Still looking for a competent shop with a better price.
Dimentions for sizes near 255/40R17s (rear) look too much bigger for comfort so I'll stick with stock. On the front, the dimentions for 245/45R17 look very similar to stock. Any experience with slightly different sizes?
Old 11-15-2004, 08:15 AM   #4 (permalink)
BeelZibub is an unknown quantity at this point
Originally posted by frank-e+Nov 14 2004, 11:44 PM--><div class='quotetop'>QUOTE(frank-e @ Nov 14 2004, 11:44 PM)</div><div class='quotemain'><!--QuoteBegin-BMWLotAttendant@Nov 13 2004, 03:31 AM
Even ware?
The 5ers have the worst tire tread ware of all the BMWs combined.* I think you better just find some tires that you like because even ware is your last concern.
[snapback]230855[/snapback]
[/b][/quote]
DON'T DO IT!!! Unless the size you choose has the same rolling dimension as the stock tyres - open the drivers door and there should be a sticker on the column which shows what 15, 16, and 17" wheel/tyre combos can be fitted without changing the rolling size.
PS changing the rolling dimensions will throw out the speedo, fuel economy etc.
BeelZibub is offline   Reply With Quote
Old 11-15-2004, 10:10 AM   #5 (permalink)
Originally posted by BeelZibub+Nov 15 2004, 09:15 AM--><div class='quotetop'>QUOTE(BeelZibub @ Nov 15 2004, 09:15 AM)</div><div class='quotemain'>
Even ware?
[snapback]231179[/snapback]
[/b][/quote]
Thanks! I think you're dead on ... since the dimentions for 245/45R17 tires are only 0.3 in larger in both section width and diameter, I thought someone out there in Beamer Land might have had expericnce with the slightly larger size. Apparently not, so I'll stick to the stock 235/45R17 to be safe. Appreciate your advice.
Old 11-15-2004, 10:53 AM   #6 (permalink)
They probably wouldn't be that bad, but I like to think my speedo is as true as possible, particularly with the increase in speed cameras over here and the police being able to nick you for doing 2-3 miles over the limit.
Old 11-15-2004, 02:46 PM   #7 (permalink)
Saggis is an unknown quantity at this point
Send a message via ICQ to Saggis Send a message via MSN to Saggis
Ive changed too 265/35/18 rear and 235/45/18 front
speeds pretty normal and 50km/h feels like 50km/h:P
im gonna test it and configure it to the new size and get back with the results
Black E39 530i 2001 with full black leather interior and antracit roof.
Saggis is offline   Reply With Quote
545 Sport Wheels And Nitto Tires 4 Sale 98bimmerhead Wheels and Tires 1 06-07-2007 04:18 PM
Tires: Performance upgrade ///M Power M-Series (M1, M3, M5, M6) 28 11-09-2005 07:11 AM
FS: 22 inch rims and tires NEW 7on22inchs Classifieds Sell & Buy 1 09-22-2004 10:56 PM
New tires for 325i wazzubmr 3-Series (E46, E90) 2 08-10-2004 05:16 PM
