Throttle Body Grease Points - BMW Forum - BimmerWerkz.com
Old 03-17-2005, 01:04 PM   #1 (permalink)
tacroteau's Avatar
tacroteau can only hope to improve
Send a message via AIM to tacroteau
I have a 1997 525i and the gas pedal it sticky (not a smooth movement when you press down) I have heard there are specific grease points on the throttle body. Is this true what should i use and where are they?
Thanks in advance
tacroteau is offline   Reply With Quote
Old 03-19-2005, 10:09 AM   #2 (permalink)
billB's Avatar
I can't think of anything other than the pivoting points under the gas pedal-through the fire wall linkages..spray some white grease if any...the rest is one cable connected to the throttle body itself (adjustable and spring loaded)..that is what I have on my 528i. You may want to consider adjusting the cable from its throttle body connection/spray some white grease....this will adjust/determine how far the pedal will travel before it is floored.
Throttle Body Air Getting In Sound (whistle) coolkolb 5-Series (E12,E28, E34, E39, E60) 2 05-13-2005 11:24 PM
? M3 throttle body on 92 325is fit steve 92 325is 3-Series (E36) 9 07-25-2004 02:56 AM
Grease points Kiwi Russ 3-Series (E36) 1 07-08-2004 08:43 PM
Boring Out Throttle Body and Heads WickedBimmer 3-Series (E36) 9 03-27-2004 10:26 AM
throttle body coolant bypass E36DRIFTER M-Series (M1, M3, M5, M6) 3 09-29-2003 10:22 AM
