Thermostat Housing - BMW Forum - BimmerWerkz.com
Old 05-22-2006, 02:28 PM   #1 (permalink)
BeemerMan's Avatar
Car: e36 328is
BeemerMan will become famous soon enoughBeemerMan will become famous soon enough
Thermostat Housing
I'm looking to replace my thermostat housing. I was looking to replace the plastic housing with the aftermarket aluminium ones. Do you guys recommend I use the aluminium ones?
BeemerMan is offline   Reply With Quote
Old 05-22-2006, 04:50 PM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
there isn't much wrong with using an aluminum housing I prefer OEM parts to aftermarket as a personal preference.
Come see me at MySpace
Old 05-22-2006, 11:38 PM   #3 (permalink)
cnn
cnn is on a distinguished road
This will help you
Just did mine entire system and posted at. All the items are addressed there:
http://bimmerboard.com/forums/posts/199986
cn
98 528i 5spd 89K
cnn is offline   Reply With Quote
Old 05-22-2006, 11:49 PM   #4 (permalink)
Moderator
Dirty_Tool's Avatar
Very nice thorough writeup. 1 comment on the water pump. There are 2 threaded holes in the water pump. Use those to thread a bolt in each side and tighten the bolts gradually to drive the pump out. Thats why they are there. With prying you run the risk of damaging the block. Not trying to be critical of your very nice work. Just making a suggestion to help everyone here.
take care,
DT
Old 05-23-2006, 01:19 AM   #5 (permalink)
BeemerMan's Avatar
Car: e36 328is
cn
98 528i 5spd 89K
Holy Moly, Great SCott!!! That's a fantastic DIY info. Thanks bud!!!
Old 05-23-2006, 09:29 AM   #6 (permalink)
cnn
Appreciate your comments
take care,
Yes I told people to be careful when prying the WP. Yes you are right, M6 bolts will help but not critical because the O-ring sealing surface is inside the hole.
The surface should be protected anyway but read the replies in the same thread.
http://bimmerboard.com/forums/posts/202498
cn
Thermostat Housing Removal E34 M20 Engine 520i tstolber 5-Series (E12,E28, E34, E39, E60) 2 05-23-2005 04:11 PM
Thermostat Installed Upside Down, Maybe? YoungExec728 3-Series (E36) 2 12-09-2004 03:15 PM
Thermostat Gasket/o-ring? Brian325i 3-Series (E36) 5 10-02-2004 02:30 PM
Leaky Water pump or the Themostat Housing RedBeemer95 3-Series (E36) 12 08-21-2004 07:13 PM
