follow the upper return hose to the housing/branch thing. It's inside of there. There is a bleed screw on it as well, and one next to the expansion (where you put coolant) tank on the rad.
Originally posted by Torque@May 2 2005, 10:05 PM follow the upper return hose to the housing/branch thing. It's inside of there. There is a bleed screw on it as well, and one next to the expansion (where you put coolant) tank on the rad.
[snapback]340196[/snapback]
the plastic screw on top of the radiator was constantley putting out steam when i opened it earlier and wasnt really slowing down neither, is my thermostat and bleed screw on the join from where the top pipe off the rad goes and the bottom pipe off the rad goes to, theres some sort of electrical connection there which is held on by a maybe m6 allan bolt, i undone it and it looked like it had some oil on it also there looks like a 10mm bolt with a crimped wire attached to it
Originally posted by bryan1970@May 2 2005, 11:11 PM if you don't know the name of the engine a year is a helpful hint. or does your valve cover have plastic or is it all metal?
[snapback]340297[/snapback]
Well, regardless of year we need to know the model...
Originally posted by Torque+May 3 2005, 04:12 AM--><div class='quotetop'>QUOTE(Torque @ May 3 2005, 04:12 AM)</div><div class='quotemain'><!--QuoteBegin-bryan1970@May 2 2005, 11:11 PM if you don't know the name of the engine a year is a helpful hint. or does your valve cover have plastic or is it all metal?
[snapback]340298[/snapback]
[/b][/quote]
its a 520i E34 J reg
its a plastic screw on top of the radiator next to the filling bottle,
there's a cast join where the bottom pipe of the rad goes and the pipe from the top of the rad goes to, is this where the bleed screw is and the thermostat is, uve then got a pipe directly below the top one which is of smaller diameter and it looks like this goes towards the back somewhere, not sure what lump it is, m10 m20
On the M50, the bleed screw on the radiator is in the same exact place. The one on the thermostat housing seems to be behind the place where the hoses come together, and I am assuming you have to pull that back to get to it...
Originally posted by Torque@May 3 2005, 09:46 PM On the M50, the bleed screw on the radiator is in the same exact place. The one on the thermostat housing seems to be behind the place where the hoses come together, and I am assuming you have to pull that back to get to it...
[snapback]340549[/snapback]
my engine layout looks quite different to that, can u tell me how to post photo's and il photo my engine tommorow, or can i have your email address please Torque
