swap m52 3.0L into 97 528i help - BMW Forum - BimmerWerkz.com
Old 05-23-2011, 09:31 PM   #1 (permalink)
deetip is on a distinguished road
Question swap m52 3.0L into 97 528i help
had a big fail this weekend wen my car my head is cracked over a major overheat so b4 i go and get another 2.8 m52 i wanted to know if i can swap a 3.0L with out major work what parts do i need the is the engine harness the same what i need to change need all the info i can get on this thanks !
thanks in advance
deetip is offline   Reply With Quote
Old 05-24-2011, 02:23 PM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
If its the newer 3.0 (M54) 2001... This replaced your M52, so have a look at this...
BMW World - M54 Engine
Even if its the older unit, they should both bolt to your existing gearbox! But you should check the crankshaft output to the clutch/torque converter to see any modifications.
In both cases I think you would need the ECU's though...
DAZ
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
95 325 swap f/s (nj) 318TI_MKZ2 OEM Parts 1 03-11-2010 04:31 PM
Help with 2000 528i engine swap (Atlanta) Dark Spoila 5-Series (E12,E28, E34, E39, E60) 0 10-29-2009 10:30 AM
Air Con Swap ??? Halfbar 5-Series (E12,E28, E34, E39, E60) 1 08-23-2008 09:54 AM
528i Auto to manual tranny swap? Jamison 5-Series (E12,E28, E34, E39, E60) 15 04-01-2006 06:41 PM
Fs: 528i 2000 528i Zpp,zsp, Zcw, Low Miles gsb005 Classifieds Sell & Buy 4 03-11-2005 11:25 PM
