What parts should I change?
If I change the rear shocks and front struts. Is it necessary to change to the strut mounts,shock mounts, bump stop and spring pads plus gaskets. Keeping in mind I don't want to lower the car. All I really want is to have the original stock ride. Right now, I get bounce when going over bumps and look to be sitting lower on the drivers rear side. I have seen complete kits out there for 1200.00. I have just got the engine running smooth again the previous owner was pretty casual about maintennace. I really like this car I just don't want to break the bank getting back to factory ride.
I see a lot of places sell boge , bilstein, meyle, kyb, shocks and struts but very few seem to stock springs maybe I'm just looking in the wrong places.
Brand new factory springs are going to be jolly expensive; think at least 350 for the set of 4; that + shocks and you're looking at the same cost as some of the best aftermarket setups out there.
How do you know if the springs are bad can they be measured? I've done shocks and struts before usually just re-use the springs if they aren't too bad. the other question is the after market parts all seem to be lowering kits and I don't really want to go that route. However if I did what is a good reliable set of springs and shocks to use?
download the Bentley manual at the top of the 5 series forum; it has ride height specs - if its out of spec, yep, they're pretty much guaranteed to need replacement.
a bad shock will cause a car to sit a little lower, but it should still be within the side to side variation; anything more is more than likely the spring.
we had a 265k mile 535 and it sat waaaaaaaay lower than any other e34 we've had
