Suspension Help - BMW Forum - BimmerWerkz.com
Old 04-29-2009, 04:03 PM   #1 (permalink)
mybrosride's Avatar
Car: 1997 540
mybrosride is on a distinguished road
Suspension Help
Have a 92 E34 (535i) that I need to replace the suspenion on. I need to know if the suspension parts from an e30 would fit my car. This is a "project car" so its taking me a while to get it all together - little at a time....
But I found a "parts car" that has almost "new" suspension on it - an e30 and I can get those parts really low. A local guy has it and offered them to me at a great price if they work since I know him personally.
thanks......
mybrosride is offline   Reply With Quote
Old 04-29-2009, 04:13 PM   #2 (permalink)
E30's have semi trailing arm rear suspension. Some info on the E34 Hope that helps a bit.
Old 04-29-2009, 04:15 PM   #3 (permalink)
mybrosride's Avatar
Car: 1997 540
thanks. but will the shocks from an e30 fit mine? and are the shocks front/back the same?
Old 04-29-2009, 05:24 PM   #4 (permalink)
mybrosride's Avatar
Car: 1997 540
what about front suspension...shocks are they interchangable?
Old 04-29-2009, 07:17 PM   #5 (permalink)
I would think the shocks for a heavier car would be quite different.
Old 04-29-2009, 08:18 PM   #6 (permalink)
mybrosride's Avatar
Car: 1997 540
thanks... just didnt know and didnt want to take a chance til i found out for sure
Old 04-30-2009, 10:11 AM   #7 (permalink)
carbonfiber dream's Avatar
Car: 1999 bmw e-36 m3
carbonfiber dream is on a distinguished road
u should just go with an aftermarket suspension. if u have the $$ that is. it don't have to be full race or coil overs but check out the bilstien and h&r sets. they handel really good and much better controll.
carbonfiber dream is offline   Reply With Quote
Old 04-30-2009, 10:29 AM   #8 (permalink)
mybrosride's Avatar
Car: 1997 540
low on cash....reason i'm trying to find something sorta "cheap" :hides:
was wanting to get a suspension off a donor car since my suspension is basically "shot"
Old 05-01-2009, 10:55 AM   #9 (permalink)
mybrosride's Avatar
Car: 1997 540
would e36 suspension fit mine?
or what would be a good place to find low cost shocks and suspension parts. I just dont have a lot of money right now to invest but need something...
Old 05-01-2009, 12:46 PM   #10 (permalink)
theres a site called myhotbmw.com. check it out. they got good parts and prices. i looked just out of curiousness at shocks for your car. bilstien has them at around 140 each. if u want sport springs h&r has all 4 for 380 + it depends on if u have self-leveling or not.
Old 05-01-2009, 12:47 PM   #11 (permalink)
E36's have multi link rear suspension (except for the compact hatchback, which uses semi trailing arms like the E30).
Old 05-01-2009, 12:50 PM   #12 (permalink)
oh and theres no chance an e36 set is going to fit. the struts and springs r designed to handel the weight of the 3 series your car has more weight to it and probibly more suspension travel so u would be wasting time. go with the bilstiens and if u can the sport springs. that thing will corner very well with that set and still have a smooth ride to it.
Old 05-01-2009, 01:08 PM   #13 (permalink)
mybrosride's Avatar
Car: 1997 540
i looked at that site "myhotbmw" you suggested but those prices are steep. I was hoping i could find some locally at a little less. i'm sort of low on cash right now, so I don't have a lot of money to sink into my car, but I want to make it "safe", and with the current suspension basically worn out, I need to find something that will work, even if it means OEM replacement or aftermarket OEM type. Maybe later I can find some quality lowering springs with better struts/shocks when I can afford them.
Oem M3 Suspension Vs. Uuc Sachs Suspension 98three28i 3-Series (E36) 4 07-11-2005 04:31 PM
Uuc Sachs Suspension Kit Stage 3 Tuned Suspension jrhaile 3-Series (E36) 0 03-12-2005 03:35 PM
E36 Suspension Work, Want To Upgrade Suspension? victorgallas Product Reviews 8 02-08-2005 08:21 AM
Sports Suspension Vs Standard Suspension skyrider 3-Series (E46, E90) 1 01-11-2005 01:07 PM
E36 Suspension Work, Want To Upgrade Suspension? Scushkadee 3-Series (E36) 0 12-31-1969 07:00 PM
