Stuck In Gear S2 While In Drive...528i - BMW Forum - BimmerWerkz.com
Old 01-11-2005, 09:58 AM   #1 (permalink)
DigPolo is an unknown quantity at this point
1998 528i...whwn I shift into D it registers S2 and drives in 2nd gear. While in P, it registers S. The car will shift into S1 manually and S2, but all other gears do nothing but keep the car in 2nd gear at 4000 RPM's. Any thoughts?
DigPolo is offline   Reply With Quote
Old 01-11-2005, 12:15 PM   #2 (permalink)
frank3 is an unknown quantity at this point
[snapback]268865[/snapback]
Did you try moving your switch by the shifter from "M" to "A"? This puts it back into automatic shifting mode and the "s" on the display will change to "e".
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Old 01-11-2005, 12:56 PM   #3 (permalink)
Originally posted by frank3+Jan 11 2005, 11:15 AM--><div class='quotetop'>QUOTE(frank3 @ Jan 11 2005, 11:15 AM)</div><div class='quotemain'><!--QuoteBegin-DigPolo@Jan 11 2005, 08:58 AM
[snapback]268932[/snapback]
[/b][/quote]
I dont see a switch enabeling me to move from M to A. Is it somewhere else on the 528i automatic? My owners manual doesn't help either.
Old 01-11-2005, 07:16 PM   #4 (permalink)
Sorry chap...can't help you here. My '95 has this switch next to the gear shift (switches from automatic to manual shifting)...thought it was standard. Maybe a "98 owner can help.
Old 01-11-2005, 07:33 PM   #5 (permalink)
billB's Avatar
you guys have too different transmissions on your cars but 2 years ago I Had a similar problem- my D was showing R the car did not move period-when it turned out to be an electronic switch mounted on the left side of the tranny itself (outside the transmission) cost me $200 for the part to replace by myself. Cannot recall its exact name? possibly Neutral safety switch? yes? No?
ANYONE??
Old 01-12-2005, 08:36 AM   #6 (permalink)
njtech is an unknown quantity at this point
gear selector switch is the problem....very high failure rate.
njtech is offline   Reply With Quote
Old 09-29-2009, 12:30 PM   #7 (permalink)
kitte46 is on a distinguished road
hello there , how did you fix this problem? any Idea on what it was??
kitte46 is offline   Reply With Quote
Old 01-16-2010, 01:46 AM   #8 (permalink)
ztitans1 is on a distinguished road
Transmission sticking in S2
Same problem here. Can manually shift to 3 and it rides OK. Please tell me more about this switch. I cannot seem to locate the part by description anywhere.
ztitans1 is offline   Reply With Quote
Bmw Track Times dutchbmw Bimmer Talk/Motorsports Talk 2 06-25-2005 08:05 AM
Need Carfax Report, Please Help F U Have Carfax Ac ozbmw 5-Series (E12,E28, E34, E39, E60) 2 05-11-2005 10:58 AM
Stick Stuck In Gear bmwforumerm3 M-Series (M1, M3, M5, M6) 2 02-25-2005 04:02 PM
BMW Ultimate Drive SoonerE39 Bimmer Talk/Motorsports Talk 8 06-13-2003 04:29 PM
