Tell me...is it a 97? (just a hunch) Electrical gremlins are the killers of E39's, apparently its hit you. There is no real direct solution to your problem, but first i would try disconnecting the (-) terminal from your battery and let it set for a few minutes. That will possibly fix it for at least awhile. I've had an issue similarly with my GPS/Radio/lighting in my 97 540i
a better description of the problem might yield you some more responses....
what does the radio do? when u say board monitor do you mean the board monitor for the navigation system? what sensor are you referring to????
what you are referring to as the board monitor is more commonly referred to as the instrument cluster.
sounds like possible ignition switch problem.....If u open the visor and open the mirror so that the lights come on do u get lights flickering on the instrument cluster?
Originally posted by No_Fear+Dec 4 2004, 03:21 PM--><div class='quotetop'>QUOTE(No_Fear @ Dec 4 2004, 03:21 PM)</div><div class='quotemain'><!--QuoteBegin-Dirty_Tool@Dec 4 2004, 12:29 AM what you are referring to as the board monitor is more commonly referred to as the instrument cluster.
what do you mean by the visor and the mirror and what are you talking about? there is no flickering and I've said what happens all the time. If you know the answer then let me know that and if you don't please there is no need for confusing me.
[snapback]243247[/snapback]
[/b][/quote]
No_fear surely you are :welcome to the forum
What DT referring to is the overhead SUNVISOR when flipped it has a sliding door; when open it turns a light; very handy to females in makeup and lipstick etc!!
What DT is getting at is a serious troubleshooting process to the ignition switch and ultimately these componenets are related if it causes your INSTRUMENT CLUSTER to flicker. He is not trying to confuse you; he is a Gentleman and a Pro and I tell you (from experience) he is an authority on BMW repairs. Trust me.
1. Did you check all the fuses in the glove box?
2. If not Remove all the instrument cluster fuses try to turn ignition on, then off, or replace fuses if needed.
3. Do the 'cluster system test', ALL lights should lit up, ALL needles should move.
Further questions:
A. Did you do anything to the car? i.e. did you jumpstart it or possibly anything that might trip a fuse? In short did you do anything to the car prior to this problem??
B. Sometimes-working and non-working instruments, there could be loose connections to be the cause.
Let us know someone will have further suggestions and good luck
billb
moisture in the fuse box? It sounds like there is a short or break somewhere. DT was helping you narrow it down. troubleshooting involves ruling out all possibilities until you arrive at the conclusion.
if at first it only acted up when there was moisture pressent, i would look for moisture in places that shouldn't be moist. now that it acts up all the time, i'm guessing the moisture caused corrosion. check fuses and any connectors for corroision.
Description: The traditional fusible link is a short section of wire that has a smaller diameter than the rest of the circuit. When current flow in the circuit exceeds that of the fusible link, the wire melts and interrupts the circuit. This type of fusible link is becoming quickly obsolete, as many carmakers have opted for newer technologies such as the cartridge style fuse element or maxi fuse. When a fuse link blows, it must be replaced.
Check the fuseable link which is a metal piece that is connected where your battery is connected from the wires. You should disconnect your battery and right next to it should be a black box, open it and with a screw driver unscrew the connectors. Sometimes it's broken or melted, and may cause unteruptions in the power supply. Or maybe the screws or connections are loose...?
It's a cheap replacement.
Open the trunk, locate battery, trace the other end of the big red wire, (+) sign on it. Does it terminate in a box? Next follow Cosmosblack advise above.
good luck
Related Threads
BMW Werkz
668.8K posts
97.6K members
Since 2003
