Strange idling problem. - BMW Forum - BimmerWerkz.com
Old 12-15-2003, 10:05 PM   #1 (permalink)
Batunas is an unknown quantity at this point
Hi all, i have recently bought a new batterie and decided to renew the alternator on my E34 520i and after that the idle is not constant as it was and when i press the gas pedal to start driving it wants to stall or when i press the brake pedal the same happens.
what could be wrong?
It´s a 1989 520i M20B20 engine, the batterie is 12V/70 Ah.
Batunas is offline   Reply With Quote
Old 12-16-2003, 12:49 AM   #2 (permalink)
Chooch is an unknown quantity at this point
maybe the timing is off ... the belt from the alternator may not be on tight ...
<span style='color:blue'><span style='font-family:Arial'>If I try to be like everyone else, who's going to try and be like me?</span></span>
<span style='color:blue'><span style='font-family:Arial'>Mi casa no es su casa, hijo de puta.</span></span>
Chooch is offline   Reply With Quote
Old 12-16-2003, 02:37 AM   #3 (permalink)
EXtech's Avatar
Batunas, you've got a big vacuum leak somewhere. Check all the vac. hoses and connections.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 12-17-2003, 04:55 AM   #4 (permalink)
Thank you all, i´ll check it.
By the way, is there any special product to use to seal the leaks?
I ask because i´ve seen something transparent, like a glue , in the joints of a friend´s car.
Thanks once again!
Old 12-17-2003, 11:56 AM   #5 (permalink)
EXtech's Avatar
No, don't use any glue or sealer on vacuum hoses. If they are soggy (mushy), dried, brittle and cracked or missing then just replace them. If they are loose then they are probably worn out or the wrong ones. Replace them.
Good Luck!
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
E46 - Idling Problem Richard Lowe 3-Series (E46, E90) 5 11-12-2005 01:31 AM
Strange Problem DeathMetal 5-Series (E12,E28, E34, E39, E60) 7 04-20-2005 01:14 PM
strange electrical problem diadpaku 5-Series (E12,E28, E34, E39, E60) 7 11-09-2004 06:19 PM
Strange AC Vent problem E60 ... Help! yates88m5 5-Series (E12,E28, E34, E39, E60) 2 07-24-2004 02:57 PM
