Steering wheel shimmy/vibration - BMW Forum - BimmerWerkz.com
Old 08-19-2011, 07:16 AM   #1 (permalink)
centuit is on a distinguished road
Hello,
I am new to this forum and I am desperate for a solution.
I have a E60 (2008 528i) with 71000 miles on it, as of about 3 weeeks ago the car steering wheel starts to shim and vibrate. this ONLY happens in the morning after the car has been sitting overnight. The problem goes away after about 10-15min of driving or applying the brakes a few time. The steering wheel does not vibrate or shim when I brake, this only happens when the car has been sitting for about 8 hours. Took it to the dealer, they cannot find anything wrong, took it to a local BMW shop and also they could not find anything wrong except for the normal wear on the vehicle.
Has anyone encounter this issue or has any suggestions ?
Thanks
centuit is offline   Reply With Quote
Old 08-19-2011, 09:13 AM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Welcome to the Werkz.
Have you changed the tyres on this car recently, or has the weather been colder in the last 3 weeks? Is it possible that your tyres are taking on a flat spot until they warm up, soften up and resume their roundness?
If you have some stands, jack your car up and put it on the stands over night, take it off the stands as soon as you ar ready to drive and see if the problem is there. If it isn't then you may have your answer, if it is, then someone else may have some other suggestions. Let us know either way.
Don't leave your car jacked up where someone might take advantage of the situation, or where its unsafe to do so.
Riding in style
Old 08-19-2011, 01:32 PM   #3 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Might sound daft but... ATF in power steering?
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 08-19-2011, 06:16 PM   #4 (permalink)
jimmythepie's Avatar
Car: 98,328i
good to see your on top of the health n safety issues Brettski,mmmmm,you look mighty like the guy on the gyrocoptor at the end of mad max,any relation?
jimmythepie is offline   Reply With Quote
Old 08-20-2011, 07:02 AM   #5 (permalink)
brettski's Avatar
No relation but I do have the DVD in my collection. Well spotted.
Riding in style
Old 08-20-2011, 07:05 AM   #6 (permalink)
Car: 98,328i
Ha! i knew it,your him for certain,bet that seven of yours has twin gatling guns mounted.
Old 08-20-2011, 07:09 AM   #7 (permalink)
brettski's Avatar
Gattling guns are two noisey for a 7er, rocket launches, they are nice and quiet, and so much more refined.
Riding in style
Old 08-21-2011, 04:20 PM   #8 (permalink)
sktn77a is on a distinguished road
What type of tires do you have and when did you get them? Some tires are known to flat spot overnight. Don't ask me how the tire manufacturers get away with this.
sktn77a is offline   Reply With Quote
Old 08-22-2011, 07:51 AM   #9 (permalink)
Car: 98,328i
more to the point what type of rocket launchers does Brettski have!
any tires in particular?that flat out.
Old 08-24-2011, 08:18 PM   #10 (permalink)
/Banned
Car: 2009 BMW 528i
kyled is on a distinguished road
Tire problem
Your tires could be out of balance, could possibly be warped brake rotors or you might simply need to go to your dealer to get your tires rotated and realigned.
My BMW 540i had a similar problem and a simple rotation at my dealer took care of the problems. Best to it sooner than later!
kyled is offline   Reply With Quote
Old 08-25-2011, 12:58 PM   #11 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Could even be the ABS !!
Eso es todo!
BMW Part Market
New Member ?
Old 08-27-2011, 09:00 AM   #12 (permalink)
Car: 2003 SMG M3 Convertible
abjm3 is on a distinguished road
Sounds like an air pressure issue, nitrogen in your tires might help as it takes longer to permeate through the tires, unlike air pressure that varies by temperature.
abjm3 is offline   Reply With Quote
Old 08-27-2011, 11:01 AM   #13 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Eso es todo!
BMW Part Market
New Member ?
Old 08-27-2011, 08:17 PM   #14 (permalink)
Ok, here is what was done so far to the vehicle.
1) I relplaced the tires with Continentals 94W, all 4 tires.
2) Balanced all 4 tires.
3) Had the front end checked by dealer and local bmw car shop:
Dealer and local car shop checked the entire front end, including bushings,
and for loose arms, again found nothing wrong.
Another observation is that the car does vibrate on speeds above 65 MPH, and the vibration is felt on the steering wheel and on the bottom of my pants.
My next move might be replacing all 4 rotors, but that is expensive, and the car does NOT vibrate when the brakes are applied, if I knew that was the problem, I would do it.
This is a serious mystery that is very frustrating...a friend of a friend told me that it could be the struts, is that possible ?
I dont want to start replacing piece by piece in the front end which will get too costly.
Old 08-28-2011, 11:32 AM   #15 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Leave the rotors alone then...
Check the centre coupling Bearing on the drive-shaft for lateral movement...
Eso es todo!
BMW Part Market
New Member ?
2008 528xi steering wheel vibration & shimmy jjskywlker 5-Series (E12,E28, E34, E39, E60) 5 12-05-2012 05:08 PM
Vibration in steering wheel when braking ppartlo 3-Series (E46, E90) 3 04-21-2011 10:52 AM
Steering wheel vibration when braking at 80 km/h 528i_tourer 5-Series (E12,E28, E34, E39, E60) 7 01-02-2011 01:41 PM
Steering Wheel Vibration... BeemerMan 5-Series (E12,E28, E34, E39, E60) 1 05-22-2006 04:53 PM
Steering Wheel Shimmy At High Speed Braking Quickman59 3-Series (E36) 12 10-05-2004 12:52 PM
