Steering problem - BMW Forum - BimmerWerkz.com
Old 12-12-2008, 10:35 AM   #1 (permalink)
cmiletti is on a distinguished road
Steering problem
Guys - I own a 2001 5301 with Sport Package wheels. The car has been great since I bought it in the summer of 2001. I am experiencing a shimming/vibration problem while I drive. I thought originally that it was a tire problem. I installed new tires (Micheling Sport A/S). The problem surfaces at any time, low speeds and high speeds. When the shimming kicks in, braking magnifies the vibration. When it happens and I slow down it feels that one of the tires has a bubble as it "hops". If I stop the car completely and wait a couple of minutes, the problem goes away and the car rides very smoothly. Could this be a bearing, ball joint, tension arm or something else? Advice is greatly appreciated.
Thanks, Carlos
cmiletti is offline   Reply With Quote
Old 12-12-2008, 11:01 AM   #2 (permalink)
It's the front I guess, I'd look at the lower control arm bushings.
Old 12-12-2008, 11:12 AM   #3 (permalink)
Yes, the vibration is coming from the front end but it goes away if I stop for a minute.
Old 12-12-2008, 11:31 AM   #4 (permalink)
Fuel is on a distinguished road
Check your alignment and see if your rotors are in good shape- if your rotors are warped or they have some "hot spots" on them they can effect your steering.
Fuel is offline   Reply With Quote
Old 12-12-2008, 11:34 AM   #5 (permalink)
Thanks. What blows my mind is that it does not happen all the time. A couple of days may go by before it happens again.
Old 12-12-2008, 11:37 AM   #6 (permalink)
My friends Acura TL would do the same thing- sometimes it would shake, and other times it would not; it seems it all depended on what steering "angle" you are turning at. He got some new drilled rotors and that fixed his problem.
Old 12-15-2008, 03:18 PM   #7 (permalink)
motoverda is on a distinguished road
Your problem could be a sticking caliper. Or it could be a rotor, but they usually do it consistently. Sounds like it is time for a brake overhaul.
motoverda is offline   Reply With Quote
steering problem BZW 3-Series (E36) 5 10-01-2008 10:04 AM
Steering Problem WRX 3-Series (E46, E90) 4 09-26-2005 11:43 PM
Steering problem ye12 3-Series (E21, E30) 2 01-06-2005 10:55 PM
Steering Problem skippaj 3-Series (E36) 5 08-02-2004 01:29 PM
Steering Problem Live_the_Curves 3-Series (E36) 0 07-28-2004 04:27 PM
