starts then dies....very rough low idle help!! - BMW Forum - BimmerWerkz.com
Old 07-07-2004, 04:21 PM   #1 (permalink)
pagz is an unknown quantity at this point
newbie here with an issue...
got a 1997 528i with 125k miles....tried to start the car the other day and it started fine but will not idle....sometimes just dies....I was told that most of the idling prblems with BMW's are related to the Idle COntrol Valve....is this true, is there any other things that might be wrong? When i hold the gas pedel down while starting it and keep it slightly depressed it is ok, but as soon as i let go, it idles really low or just dies....The check engine light does not come on and i am able to drive it ok as long as i do not let off the gas pedel.....any thoughts...where is this idle control valve anyway???
Help Please ghead
pagz is offline   Reply With Quote
Old 07-07-2004, 09:38 PM   #2 (permalink)
E28boi's Avatar
E28boi is an unknown quantity at this point
The idle control valve is connected to your intake boot. It is round, with an electrical connector.
You may also have vaccum leaks or need a valve adjustment.
86 535i
99 Passat V6
E28boi is offline   Reply With Quote
Old 07-07-2004, 10:16 PM   #3 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
inspect the MAF sensor..
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 07-07-2004, 10:55 PM   #4 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
CBA is right, check the mass air flow (MAF) sensor... this is the big hose (housing) connected next to the air filter going into your engine block. Remove the coneector (wiring harness) and inspect screen visually. Also check the orings inserts into the air filter housing and intake boot, check for loose wiring connections.
LOS
Old 07-08-2004, 12:57 AM   #5 (permalink)
silverlea is an unknown quantity at this point
There are many possibilities why your car will not idle...........the easy one is the idle valve which is simple to replace.The fuel pump supplying the go-juice to the injectors could be failing,or you could have a blocked fuel line and soiled filters.your local dealer could hook your car up to a smart-scope and nail the problem quite quickly.
trust you find the problem.
chers.
SILVERLEA.
silverlea is offline   Reply With Quote
Old 07-09-2004, 02:04 PM   #6 (permalink)
Took the car to a master tech who tapped on the Idle control valve with a long screwdriver.....did the trick, car started idling correctly. So the Idle COntrol valve needs to be replaced. Thanks for all your suggestions!
89 325i Rough Warm Idle And Other Odd Problem mattpark 3-Series (E21, E30) 8 03-19-2005 10:46 PM
Rough Idle After Spark Plug Change parker1000 3-Series (E36) 17 03-04-2005 01:06 AM
Rough idle. Help!! PhunkDJti 3-Series (E36) 6 05-10-2004 12:25 PM
very hard cold starts+ rough idle ????? jshores7 3-Series (E36) 5 03-02-2004 08:57 PM
