Starter Help 1997 E39 - BMW Forum - BimmerWerkz.com
Old 03-06-2004, 11:29 AM   #1 (permalink)
mochoa5620 is an unknown quantity at this point
Talking
Does anybody know if the E39 has a ignition solenoid that could be bad instead of starter. My engine is not turning over once key is turned. Battery is fully charged and no other indication is given.
mochoa5620 is offline   Reply With Quote
Old 03-06-2004, 04:06 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
probably the starter, i dont recall the solenoids causing a non-turnover. but i could very well be wrong on that. (my e39 knowledge is limited)
Old 03-06-2004, 04:07 PM   #3 (permalink)
b.werrell is an unknown quantity at this point
I had same problem it was the solenoid on the starter motor.
When I turned the key Nothing happend.
Get somebody to turn the key and then give the solenoid a tap with a metal bar ie trolley jack handle.
Cure was to replace starter
If it's a m52 engine you can do the job from the top
and euro car parts charged 95 pounds for the starter.
hope this helps
b.werrell is offline   Reply With Quote
Old 03-06-2004, 04:34 PM   #4 (permalink)
ex owner/admin
Furious's Avatar
good info b.werrell also welcome to the forum.
Old 03-07-2004, 12:14 AM   #5 (permalink)
EXtech's Avatar
is your car a manual?? could be a clutch switch also or a gear selector switch on an automatic. Point is, I would be sure what is wrong so you don't waste money or time. Good Luck !!
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 03-07-2004, 11:10 AM   #6 (permalink)
I checked the switch and found it almost apart in two pieces. It seems that a small amount of brake fluid leaked from cluth master cyc and managed to get inside switch and ruined the little electronic board inside. This swithc is a non-contact type and has a small IC board that measures weather is open/closed.
You guys saved me $200 + labor on new starter. Thanks alot.
Car Won't Start Starter Relay Suspected BImmerN2B 3-Series (E36) 5 06-24-2005 06:36 AM
Need Carfax Report, Please Help F U Have Carfax Ac ozbmw 5-Series (E12,E28, E34, E39, E60) 2 05-11-2005 10:58 AM
