Check the front control arms for binding, as well as driveshaft flex disk and center bearing. I honestly can't see anything else doing that.
As far as the SRS light; just learn to live with it (as I have also
). The dealer will want an arm and a leg to scan the thing and tell you what is wrong with it, and then even if nothing is wrong, they'll charge you about a million to reset it ...
