Squeeky Steering Wheel - BMW Forum - BimmerWerkz.com
Old 10-16-2004, 11:35 AM   #1 (permalink)
dberger's Avatar
dberger is an unknown quantity at this point
Thumbs up
Today my steering wheel has a squeek when I turn it left or right. Is the something I can do to stop the squeek?
thx ghead
Dan
dberger is offline   Reply With Quote
Old 10-16-2004, 03:14 PM   #2 (permalink)
Slvr e39's Avatar
Car: Dinan Stg 1 M3
Slvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond reputeSlvr e39 has a reputation beyond repute
Send a message via AIM to Slvr e39
All that I can think of to fix the squeak would be to find that actual mechanical part that is squeeking you could put a MINIMAL!! amount of dw40 or some type of silicon spray to stop the squeak. DO NOT GET IT ON ANYTHING ELECTRICAL!
The easiest way to get to that part would most likely be to go under the steering wheel column. You will see a screw there, and the whole bottom half of the plastic surrounding the steering column should come off..
Dinan Stg 2 Phoenix Yellow M3
Slvr e39 is offline   Reply With Quote
Old 10-16-2004, 03:16 PM   #3 (permalink)
Slvr e39's Avatar
Car: Dinan Stg 1 M3
I am kinda having second thoughts about telling you to use WD40 or Silicon spray just because of the amount of electrical in there. I would say go for it with a single small spray if u find the exact contact point. SOME ONE PLEASE VERIFY that that is ok to do...
Old 10-18-2004, 11:27 AM   #4 (permalink)
dberger's Avatar
Could it be that I maybe low on power steering fluid?
dberger
Old 10-19-2004, 06:21 PM   #5 (permalink)
85bmw535i is an unknown quantity at this point
Is it squeaking like its coming from your tires like under the car or in the engine compartmet
85bmw535i is offline   Reply With Quote
Old 10-19-2004, 06:47 PM   #6 (permalink)
TMac325is's Avatar
i think he is talking about within the steering wheel column in the interior.. all it is is something rubbing up against another part of the column just find what it is
Old 10-19-2004, 07:40 PM   #7 (permalink)
dberger's Avatar
Yes, it is coming from the steering wheel. Sounds like it could be rubbing but not sure. Just happened all of a sudden.
Old 10-20-2004, 06:46 PM   #8 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
it usually happens when weather changes... from severely hot to cold. mine squeaks for a few days every few months and stops eventually... learned to live with it.
edit: reason it happens is plastic expanding or shrinking.
Old 11-01-2004, 03:16 PM   #9 (permalink)
gasper11 is an unknown quantity at this point
[snapback]214387[/snapback]
From my experiuence, your problem is the lower steering column bearings located in an impossible place to lubricate. Some folks have suggested that you can use WD40 and an 18" straw to "saturate" the bearings from the very limited access within the engine compartment. They suggest that you should jack the car and access from below.
I reasoned that wd40 flows down... so I drilled a 1/16" hole slightly above the bearings where the steering column meets the firewall. (this required removal of the under-dash paneling) then sprayed about an ounce of wd40 in the hole. Covered the hole with tape...
No nore squeek. At least for now...
gasper11 is offline   Reply With Quote
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
Steering Wheel Upgrade Options gmal 5-Series (E12,E28, E34, E39, E60) 0 10-28-2004 08:25 AM
E36 Steering Wheel MrTwisties 3-Series (E36) 6 07-23-2004 01:36 AM
Triangle 3 spoke Sport Steering wheel woobiee Classifieds Sell & Buy 11 10-03-2003 03:08 PM
