Spark plug thread snapped e39 - BMW Forum - BimmerWerkz.com
Old 04-12-2008, 02:41 AM   #1 (permalink)
mmclaren is an unknown quantity at this point
Ok i think the title has summed it up.
Today i was happily replacing my spark plugs as you do, when unscrewing a spark plug, i found it came up with no thead on it.. Look down in the spark plug well, and i can see the thread is still in there.
I realise this is a major problem, but can anyone give me any advise on fixing it.
Thanks Michael
530i m sports 2001
mmclaren is offline   Reply With Quote
Old 04-12-2008, 10:04 AM   #2 (permalink)
You will probably have to have somebody heli-coil the head.
The most important thing you can do here though (wether you heli-coil it or not) is to vacuum out that cylinder with a straw on a shop vac as best you can.
Old 04-19-2008, 07:25 AM   #3 (permalink)
GSXRYDER is on a distinguished road
EZout
Get the right size EZout ...they have left handed threads and as you screw it in it backs out the threads...pretty easy!
GL
Get EZouts from Craftsman, Harbor Freight, Snapon any tool guy will know what they are.
GSXRYDER is offline   Reply With Quote
Old 04-19-2008, 11:24 AM   #4 (permalink)
Moderator
Dirty_Tool's Avatar
depending on how bad it is then like gsx said you can try an eazy out or you may even be able ot just walk the threads out with a screwdriver or small pick tool. Obviously the most important thing is making sure that no metal particles make their way into the combustion chamber. When you're done even if you dont drop anything in there you should still blow some compressed air in to the cylinder and listen for anything moving around in there just to make sure that nothing fell in there when removing the plug originally.
if possible post some pics of the spark plug as well as the spark plug bore in the cylinder head.
DT
New Spark Plug Wires For All You E30er's(Bavauto Plug Wires) Bmw1990 Product Reviews 2 02-19-2009 02:38 AM
Spark plug wires triniskunt 3-Series (E21, E30) 3 10-18-2007 05:32 PM
Spark plug wires triniskunt 3-Series (E21, E30) 0 10-17-2007 07:24 PM
Does This Spark Plug Look Normal ? pcy 3-Series (E36) 2 03-19-2005 04:40 PM
Spark Plug Wires Halon 3-Series (E21, E30) 5 06-23-2004 08:58 PM
