Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 12-05-2004, 10:23 AM   #1 (permalink)
Photos: 0
fdeee is an unknown quantity at this point
Hi. I have a 1997 528i with 100,000 miles on it. lately I have noticed a smoky burning smell coming through my vents inside the car when I use the heater. It does not come through when I am using the a/c. The other day while waiting in line at the bank I could even see a little smoke coming from the vents. It seems to go away as fast as it comes. Anybody have any idea what this could be? I also notice my Trans shifts hard when car is cold. Thanks.
fdeee is offline   Reply With Quote
Old 12-05-2004, 12:31 PM   #2 (permalink)
billB's Avatar
Photos: 0
fdeee to our forum
Sounds like oil leak? hitting exhaust manifold somewhere. Check for oil leaks. As to the tranny rough shifting when cold? To minimize it: when warming up I usually engage it in drive while holding breaks for several minutes to allow full circulation of fluid. It works; just make sure it has the proper amount of fluid. NOTE: NO dipstick!!
regards
billb
Old 12-06-2004, 06:39 AM   #3 (permalink)
Photos: 0
Originally posted by billB@Dec 5 2004, 01:31 PM
fdeee to our forum
regards
billb
[snapback]243875[/snapback]
Thank You Bill.
Old 12-06-2004, 08:52 AM   #4 (permalink)
Idle Member
///M Dream's Avatar
Photos: 0
///M Dream is an unknown quantity at this point
i doubt its an oil leak, sounds like your heater core would need to be replaced.
check with a dealer, but i think thats what it is. what does it smell like?
good luck
///M Dream is offline   Reply With Quote
Old 12-06-2004, 08:59 AM   #5 (permalink)
Photos: 0
good luck
[snapback]244366[/snapback]
It smeels like some type of lubericant or oil. It doesn't smell like engine oil burning. I also get a faint smell of anti freeze when I first fire up the heater.Thanks for the help.
Old 12-06-2004, 09:02 AM   #6 (permalink)
Idle Member
///M Dream's Avatar
Photos: 0
its a leaky heater core, what you smell is the antifreeze leaking out and into the innterior of your car
Old 12-06-2004, 09:05 AM   #7 (permalink)
Photos: 0
[snapback]244370[/snapback]
What would be the burning smell? I can't figure that one out.
Old 12-06-2004, 09:11 AM   #8 (permalink)
Idle Member
///M Dream's Avatar
Photos: 0
what burning smell? is there a smell other than the antifreeze?
Old 12-06-2004, 09:23 AM   #9 (permalink)
Photos: 0
[snapback]244375[/snapback]
The burnig smells like some kind of oil. I even saw smoke coming threw the vents.
Old 12-06-2004, 09:25 AM   #10 (permalink)
Idle Member
///M Dream's Avatar
Photos: 0
that smoke coming out is the antifreeze, its one of the warning signs that the heater core is out. also, there might be some fog on the windshield and/or antifreeze on the passenger side floor.
Old 12-06-2004, 11:47 AM   #11 (permalink)
billB's Avatar
Photos: 0
[snapback]243810[/snapback]
Burning smell is burning smell......Foggy winshield, oily winshield, fog through vents is NOT burning oil. The latter symptoms are related to heater core. Which one is it?
CHECK the post coolant smell.....posted by "numberthree"
Old 12-06-2004, 11:53 AM   #12 (permalink)
Photos: 0
Originally posted by billB+Dec 6 2004, 12:47 PM--><div class='quotetop'>QUOTE(billB @ Dec 6 2004, 12:47 PM)</div><div class='quotemain'><!--QuoteBegin-fdeee@Dec 5 2004, 04:23 PM
[snapback]244459[/snapback]
[/b][/quote]Bill. I have to say it is smokey smell it is not anti freeze. That said I also have the slight smell of anti freeze when I turn on the heater but they are two diffirent smells.
Old 12-06-2004, 11:57 AM   #13 (permalink)
billB's Avatar
Photos: 0
Two things:
A. open the hood and take a look at everything and anything.....Smoke? smell?
B. Does your winshield gets GREASY,OILY foggy?
Old 12-06-2004, 12:51 PM   #14 (permalink)
Photos: 0
Originally posted by billB@Dec 6 2004, 12:57 PM
Two things:
[snapback]244468[/snapback]
Bill I had BMW check the engine for leaks and they found nothing. The Service Advisor said it could be the electric motor burning out but I don't think so. Its the damndest thing. Could it be power steering fluid or trans fluid burning?
vB code is On
Me on my car, on the Freeway! 325eXTATIC Picture Showroom 20 01-19-2006 11:49 AM
Chip Made My Car Slower gonzonick 3-Series (E36) 12 10-25-2005 03:46 PM
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 09:08 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
