Side marker light bulb replacement - BMW Forum - BimmerWerkz.com
Old 10-20-2009, 09:21 AM   #1 (permalink)
Car: 1995 525i Calypso Red
Pete Lech is on a distinguished road
After breaking one side marker assembly on my 1995 E34 while trying to change the bulb, I have another bulb out. The dealer only sells the complete light assembly, not a replacement clip.
What is the trick to getting access to the bulb to change it?
TIA.
Pete Lech
1995 525ia
Pete Lech is offline   Reply With Quote
Old 10-20-2009, 09:30 AM   #2 (permalink)
Do you have a pic? There is sometimes a bit of confusion; the fender (behind front wheels) mounted turn signal repeaters (if so equipped) are sometimes believed to be the side markers. The actual side markers (with parking lights) are the front corner lights.
Old 10-20-2009, 09:36 AM   #3 (permalink)
You are correct. It is the turn signal repeater that I need to replace the bulb in.
Old 10-20-2009, 09:40 AM   #4 (permalink)
Have you looked at realoem.com ?
Old 10-20-2009, 10:23 AM   #5 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
The side repeater, in the wing ? on mine you just get a small flat screwdriver ( use a cloth to protect bodywork) in the rear end and gently lever and it pops out, but that's on an e38 7 series.
When replacing just pull the tabs gently apart and they will pop back in.
Old 10-20-2009, 11:43 AM   #6 (permalink)
Thanks, I will try that. The picture on realoem.com doesn't show the tab. I don't want to have to glue another assembly back into place.
Old 10-23-2009, 06:27 PM   #7 (permalink)
Pictures of the lights attached
Here are pix of the two lights in question: I need to know how to open them to replace the bulbs.
2 more just burned out so guess I need to replace all three as #4 is due to go anytime.
Jeez, only got 15/130K miles years out of these
Side marker light bulb replacement-mini-img_6776.jpg   Side marker light bulb replacement-mini-img_6775.jpg
Old 10-23-2009, 07:51 PM   #8 (permalink)
Those are side markers that light with the parking lights. On my E30, there is a notch on one end that a screwdriver can get into in order to pry the light out.
Old 10-23-2009, 08:17 PM   #9 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
One side has a little indentation/slit for a screwdriver. Insert a thin screwdriver and push in towards the inside of the sidemarker against the metal clip. When it's in far enough it will be able to clear the molding and pop out.
That said, they are fairly flimsy and break all the time - I've had to glue them back before. Sucks, but oh well.
btw, you can get euro bumper moldings and do away with them altogether.
Old 10-24-2009, 12:38 PM   #10 (permalink)
Car: 91/BMW/535i
DonJ is on a distinguished road
You don't have to get the sidemarker assembly from a dealer. Look around at some online part shops - I replaced mine because it was completely broken out. It still cost me $24 but it is probably cheaper than what a dealer wants.
DonJ is offline   Reply With Quote
help with side marker install E36GRIP 3-Series (E36) 5 08-19-2009 07:21 AM
2003 530i Fog Light Bulb Replacement SAL530i New Members Check In 0 12-07-2006 01:09 PM
Side Marker Light Scotty Dangles 5-Series (E12,E28, E34, E39, E60) 3 06-01-2005 03:55 PM
Side Marker Lights dzell 3-Series (E46, E90) 0 02-27-2005 05:47 PM
Side Marker Lights witeshark 3-Series (E21, E30) 2 10-10-2004 08:33 PM
